amazing deal on those batteries!
Yeah, these batteries are really nice, people get between 840mAh and 1000mAh in the Aliexpress reviews and you get also a battery carrier.
Good suggestion. Thanks!
I guess I need to backread as I received my UT01 a few days ago and absolutely won't turn on. Sigh.
I think this is the last time I'm ordering FL online as the return policy and shipment is too much of a hassle :(
oh, I only know a flat cut.
What effect has this pyramid shape on the beam?
Or is it more a cone?
Joe
In total, it’s a pyramid and I do not know if it changed a lot, unless I actually do it flat.
Got my third. Needed wire to work. Still no turbo with good battery. Did engineering mode and got turbo. Happy.
I gotta say for 10 bucks it’s a very nice 14500 EDC light. Seems well made and looks much better than any of the pics I had seen.
I may replace the driver and UI but just to beat around, it be fine without the swap. I just can’t help myself, it’s screaming mod me.
Over all I’m very pleased with the light, better than I was expecting.
Yes, it is a nice quality for the price, packaging is good, ordered my fourth yesterday because it is easy to gift since it also works with AA and has presentable packaging.
I approached the subject again and scalped the diode completely. Now it resembles the HP-L HI version. For this I changed the paste and polished the substrate diode because it was not equal. Effect? Wow, it shines noticeably harder. Of course, I made measurements:
Before changes, 114 lux with 5m:
After changes, 156 lux with 5m:
And some photos from the modification:
^ looks good! :+1:
Does anyone encounter this issue:
UTorch UT01 occasionally (or fairly regularly) will not turn OFF (have to unscrew the tail cap in this case):
Maybe it’s an electronic switch problem? How to fix it?
Hi dear, where did you get it for ten bucks?
thanks
Check this one
Thanks a lot
Anyone know the maximum amps a utorch ut01 will draw with a 14500?
Deciding if I should go with a Sanyo UR14500P (better at ~ 1A or below) or an Efest 14500 (better at say 2A-5A but less capacity)
About 2 amps. I have used the Sanyo several times in the ut01 and they work fine. I have used the efest to, I don’t see any noticeable difference between them in the ut01. If you need more current than 2 amps in another 14500 light go for the efest to use in both.
Is there still a way to get it for 10$?
Thanks,
Right now its going for a little more, if you’ll keep watching Fin17 thread I’m pretty sure it will pop up again with the special price. You could PM him which you will have to do anyway when the deal comes up again. The code is not public.
Thanks I’ll do that!
