I quite like my A3S. In my opinion, it’s one of the best stock zoomies on the market. A few easy mods make it even better.
What I liked:
The zoom in my A3S is butter-smooth. Smoothest zoom mechanism I’ve seen on a zoomie yet. It’s just a joy to use.
The beam pattern goes from a wide even circle in flood mode to a small blurry circle in spot mode. Unlike most cheap zoomies, the A3S does not focus all the way to a sharp image of the LED surface. The result is a very pleasing beam pattern at the expense of slightly less max throw.
The beam pattern is absolutely flawless. Completely artifact free. No rings or other artifacts at all, regardless of what zoom position the lens is in. Cleanest beam pattern of any zoom flashlight I own (and I own dozens).
*The threads are compatible with threads for the Convoy S2*. This means you can use alternate battery tubes for the Convoy S2 and Jaxman E2L. the thread length is slightly different though. I’m using mine with a Jaxman E2L 18500 tube. I bent a thin strip of copper into a C-ring wedged behind the driver in the head so that the slightly shorter Jaxman tube can make contact with the back of the driver.
The UI is very well designed. It’s similar to that in Olight’s. Long press for low, double-click for turbo. Press-and-hold to cycle up modes. Single-click from on to turn off. Single-click from off to turn to high. Biggest disadvantage of the UI is it has a low, but does not have moonlight.
The light is substantially brighter when run on a low-resistance IMR cell. I haven’t looked at the driver, but perhaps it is using a FET. The upshot is you can “hot-rod” this light simply by replacing the battery with a better cell.
Fit and Finish is excellent*.
What could be better:
Head is quite a bit wider than the lens opening. The biggest advantage of this is very slightly wider max flood mode as the edges of the bezel are further away so block less of the flood. In my mind, I don’t think this tiny gain is worth the extra width in the head. I would have preferred a narrower head (for more comfortable pocket-carry), or a wider lens making more use of the extra width (for better throw).
Battery tube. The light is designed to use the supplied battery that comes with a built-in USB socket. This cell is quite a bit longer than most 18650 cells. The springs in the battery tube aren’t long. Most 18650 cells won’t work in this light without modification because the stock springs are too short. This can be fixed by using longer springs, or shorter battery tubes.
Hey Firelight2…….Thanks for the info about the battery tubes interchanging and all.
Was the bezel glued in tight on yours like it seems to be on the one I got? If so how did you get the light apart and did it cause any damage in doing so , if you don’t mind me asking in the public thread.
Actually, I didn’t disassemble the head on my A3S. When I did the mod, I placed the copper c-ring onto the outside of the driver, wedged between the driver and the threads at the bottom of the head. Head disassembly was not required.
I have removed the bezel on my Wowtac A3. It was not glued, but had an o-ring that made the bezel quite difficult to unscrew. I was not able to unscrew it with bare hands. I used 3M indoor stairway grip tape (rubber tape), to provide additional grip on the head and bezel. With that the bezel unscrewed easily. I do not know if they added glue with the A3S.
I have actually tried gripping mine with rubber on the head and wedged the bezel against wood and then ended up taking chunks out of the wood without ever moving the bezel at all.
I just asked them about the A3S last night and got the reply today……
They are sold out at the moment , but will be back on the Amazon site when they become available.
I did not get a time frame , but I am pretty sure it will be after the big Spring Festival in China , which I think is still another 2 weeks or so before it is over.
I know I’m late to this reply. But yes I am using the battery they issued. Seems to flicker more when I turn the flashlight vertically. Definitely sounds like a short battery issue.
Just saw the review on that, looks like a great tactical light!
I kind of hope they don’t change the A3S driver though…
What I’d rather see done is they shorten the battery tube and dump the USB battery idea, the longer tube to accommodate the USB battery creates an issue for using a lot of different cells. I guess it was a “quick and dirty” way to compete with some of the newer zoomies with built-in USB charging. Pretty much any of the high drain IMR cells will need a magnet to the negative side (per Newlumen’s helpful suggestion) whicht seems like a good setup on this for 18650.
Firelight2’s revelation about the Convoy/Jaxman tube lego is what really has me stoked for this light (Thanks again Firelight!) I’ll run an 18500 Jaxman tube as well, I’ve got some Efest purple IMR 18500 high drain cells to use in it. Only drawback is shimming the driver side for contact, because that probably won’t be something that easily goes in and out, so swapping back and forth with 18650 might be a PITA. But I’ll more often be swapping back and forth with a 18350 Convoy tube and Aspire INR 1100. I’ll try using a ring of 14g or 12g solid copper wire (Romex type) for the shim mod, if that works.
Robo, you probably know this but this review isn’t linked in your sig, no biggie but thought I’d remind in case you forgot, I use those links to jump around your reviews.
Also I guess they are the same light body but the first 2 sets of slide-show photos are the A3, not the A3S, no biggie there either, just sayin because when I look at those pics I have to check if I’m in the right review :person_facepalming: :laughing: . Maybe you could just make a note of that somewhere around the pics to avoid confusion.
Something else I want to point out on this to avoid confusion: In the “listed specs” (manufacture provided) it shows “Reflector: TIR lens” however it appears to be an aspheric on this. (and hopefully is) Wowtac really needs to fix that, unless there’s some type of hybrid thing going on with this?.
I bought this a week or so ago. But right now it’s boxed up ready to go back to Amazon. I’m sitting on the fence, but leaning toward returning it. The fact that I also bought a Thorfire TK15 that can pretty much serve the same use would make it easier to let it go.
I like the side switch, the UI, and the light output. And with the 20% off, I got it at a great price. But the zoom is annoying. The seal is so strong between the zoom and the body that when you slide it out, it wants to pull back because of the slight vacuum produced inside. You have to hold it a couple of seconds for it to get fixed in place. The same kind of thing happens when you pull the zoom back. Do zooming lights like this every loosen up?
Mine doesn’t do that at all, did you get the A3S or the A3? Pretty sure I read somewhere of that same problem on the A3, and it’s been corrected with the A3S. This review is of the A3S.
The A3S is more expensive, the A3 is a close out.
A3…….(600lm) $19.99
A3S…(1000lm) $29.99
Can’t compare a non-zoomie to a zoomie, if they serve the same use for you then you probably don’t need a zoomie, around here these are usually bought specifically for the zooming function.
