☢ [Bilakos10 Premium Deals] ● Astrolux FT03 SST-40 ● Astrolux A01 UV ● Seeknite X6S ● JCD 8898 Hot Air Station ● SQ-D60
Can you please try and get us a code for the following charger?
Miboxer C2 - 4000 Universal Smart 2 Slot Battery Charger - EU BLACK
Active codes
11/2/2018
Available for these countries:
HK,US,CA,MY,TW,GB,IE,AU,NZ,IN,SG,ZA,PH,GR,NL,HU,SK,CZ,HR,BG,SI,RS,TH
Code for Opus charger is only for US version (US plug) useless for most of the listed countries…
Code for EU version maybe?
:+1: I will definitely try to get a deal on that charger!
Is it possible to get a code for this charger? Opus c-100 https://www.gearbest.com/chargers/pp_345597.html
Look good and show up a flash price @usd11. 29 in the video
Many thanks
I will see what I can do.
But even the US version works as expected in European plugs using a simple adapter.
Any chance for Soshine 18650 boxes and EA X6?
Sorry, I know I’m repeating myself. :slight_smile:
Active codes
12/2/2018
The deals above are available for all countries!
There is a few other items on that website with discount codes that are “stolen” from this thread. I suspect it might even have a software written specially to look for keyword like “bilakos” so that it can be automated.
In fact, just 1-2 weeks ago, I saw another code stolen from this thread and put on the Australian ozbargain website. See link here.
It is really disgraceful.
If feasible, my suggestion is to get the moderator to lock down your thread to registered members only with post count of say 50 or even 100 posts, and/or members here for a minimum amount of time. Otherwise you just get “thieves” that will constantly come here to steal your discount codes.
That’s indeed my code and I don’t know how exactly they have gotten hold of it.
Most probably another GB employee is leaking some of my codes.
Either way, the code is currently inactive and won’t get activated any time soon :stuck_out_tongue:
Thank you very much for getting my attention on the subject!
:+1: :beer:
Your thoughts are correct but I am not sure if the forum supports limited access to specific threads.
I guess I will have to accept that there will always be people wanting to repost my codes without permission…
What I don’t understand is why you don’t get credit for them if they are your codes ?
Got one of them UV S2+’s, thanks bilakos!
The credit is given to me through the use of my affiliate links, not the use of my codes.
bilakos…you haven’t had any codes valid for Poland in a long while…I read it many times that the requesting codes can’t decide what the list of countries would be. But others are getting codes valid here.
Do you know why is it so? Could you tell us more about the process?
This is important to note for anyone buying through this thread that isn’t aware of that, someone unaware may just search for the item on GB and buy it with your code, but didn’t use your link.
EDIT: I actually almost did that once because I had the item save in my favorites on GB, then realized I didn’t use your link and went back here and re opened the product page from your link!
You might want to consider noting it in your sig. or add it on every post you do… Something like: “Please use my links only for purchasing, thanks!”
To be honest I don’t know why GB doesn’t include PL in my countries list.
On the other hand, I have some good news to announce.
For the next while, except from country specific codes, I will also be given codes that will work for all countries :slight_smile:
I think I have done that quite often, opened my Gearbest account under a separate tab and assumed the credit went with the named code.
OOPS!
Yes, you must always use direct links from this page.
bilakos10, maybe you can update OP with this info.
