Thanks a lot. That actually makes sense, it was scratching and with audible noise.
I was suspicious there are dirt on carbon fiber detent ball. So I pointed and sprayed lubricant on the detent ball, hope that it disolve and clean any dirt there. This is my first knife with cf detent ball, so i was thinking WTH, maybe stainless steel ball is better.
(My preferred opening method on these, once I got this method down I use it for all my knives with a hole and am unwilling to go back to any other method!)
The “Spyder Drop” :
Only takes a little practice to master, then you’ll be doing it every time you draw out the knife! It’s just so natural!
No, that works fine, I was referring to pushing the lock and snapping wrist, there’s some vids about this but its tougher on the ganzo cause the lock spring seems stiffer and you cant get much of a grip on the scales due to its smaller size, also the lock has a U shape and its kinda painful when you try it over and over, similar to the G10 pain on the axis models, but iindex finger is being used and abused. it probably is easier to do on larger handle models. I tried some oil on the pivot but seems worse, maybe I will loosen the screw a touch, for $7 your not gonna go wrong if you can find that deal again
I took apart dozens of my folders with ball bearings for cleaning the past years and adding some light lube (not a greasy one) always made them better.
That U shape on the lock is called the Boye dent (it’s for preventing unintentional unlocking).
Ganzo F759M and my old school Spyderco Delica side by side. The Ganzo weights 66 g (2.33 oz) while the Delica with the lanyard 57 g (2.01 oz).
Guys, some posts ago I think I saw someone post a triangular diamod honning/sharpenening device pretty cheap to improve the factory edges not to re-profile blades where is that link i want one one those things.
On my knives I feel that grease makes the ball bearings slower, oil is no problem.
But I use my SRM Land 910+, my Malyshev Gnome, and my Vespa Neon without any lubricant at all.
Working like a charm and doesn’t collect so much dust.
Only my TiLock clone and my Real Steel Griffin run on bearings with some grease but they are no flippers even though they could flip great with attachable flipper tabs like on the LionSteel Tre…
Well, order 2 of these little fellas to my address (when they are on sale if you like) and get one back with a cf scale.
I could even include a (simple) pattern and fill it up with gidt epoxy.
Just made some shopping cart coinless keys and included a smiley one one and alien eyes on the other one.
Of course I forgot to take pics before gifting it to my sister and my b-i-law.
The skull didn’t work out so well but I guess I’ll try another one.
wow, yes I see what you mean there. I only have a few frame locks (I’m not really fond of them) but none of mine have a cutout on the other side of the handle like that. That is definitely design flaw IMO. Looks like a high chance of it closing up on you when you grip the handle, pushing the lock bar back off.
On the ones I have gripping it would move the lock bar further in, thus locking even tighter.
I think i could manage with the “design flaw” on the 5009 but the knife im looking for is for my 11yr old son so i wouldnt dare give him that.
He is already flicking my 7010 fully with his thumb
