Should have mentioned, but I don't really liked de-omed LEDs, or more specifically the color of them Thanks anyways though
Xp-l HI likely. Some companies are building amazing throwers from the XHP35 because its capable of near 3000 lumens and candlepower numbers in the mid 500,000+ range and more.
The XHP70.2 or orignal 70 arent ever going to make a comparable thrower when put against smaller die emitters like the XPL and xp-g series.
Pretty much physics dictate small die+ large reflector equals high candlepower and throw.
Then XP-L HI is next best.
Thanks. So if I'm correct, the smaller LED with more candlepower will out throw a larger LED with more lumens?
Thanks, I'll probably try the HI and the 35, and whatever else is recommended to get a feel for them all.
Depends on what LED.
Just because one is smaller doesn’t mean it will outthrow a bigger one.
But the XP-L HI is the highest stock intensity one that cree has available.
Sorry if I'm being annoying, but this is my last question. Between the XPL-HI and the XHP35, with would get farther throw?
The XPL HI does.
Thanks
They have a flat silicone layer instead of a dome, so there is no need to remove the dome yourself.
Does the XPE2 belong in the thrower category in the right torch?
They are very similar though. The luminance difference is so small that it can hardly be seen. The XHP-35 HI has a 50% larger die though, so more lumens and a fatter beam at almost the same luminance. Because of the higher Vf it can also be driven by more compact drivers (lower currents).
What is a die? Is it the size of the LED?
The die is the the Yellow Square that Emits light , The colour of the Die Depends on the LED UV/IR/White….
there are LEDs with 4 Dies Connected Together like this
Thanks
All this discussion misses an important point:
to get the most throw from a LED you need to drive it to the max.
This is not what typically happens with any of the mentioned LEDs.
What LED would be good for maximum drive?
Any. You just need the right driver for your host. Which may or may not be available.
So if you have a host, tell us what it is. If you don’t - ask us to help you find the one that’s right for you.
I'm planning to use the Astrolux X when it comes out but I don't know what driver it uses, so I'll guess 17mm
You are unlikely to get some definitive answers until more is known about the light.
But:
Do you intend to keep USB charging? Replacing a driver while keeping charging may not be easy. Also, removing it will free some space for large drivers. Which is likely unneeded, but we (I?) don’t know yet.
You intend to run it off a single cell, a pair of 18350s won’t do, right?
