So even with AAs it steps down from 240 to around 80 lumens?
Nitecore D2 2 Channel Digital Battery Charger
Nitecore Charger - Nitecore D2 2 Channel Digital Battery Charger
Price: USD 15.99
I didn’t even check the AA or Eneloop when I did my testing but……….
I have just ran the light with the Eneloop Pro for 7 minutes and it did not step down and was at 253 lumens at the 7 minute mark.
EDIT: I need to mention I have already changed the emitter to a XP-L V6 so the lumens are higher than what the XP-G3 will be.
Interesting. Is there any patter to what level of lumens causes a light to step down?
It seems to be a thermal step down really. The light gets much hotter with the 14500 than with the AA or NiMH.
One more question about this one. I have UltraFire protected 14500s that are a hair under 50mm. Will they fit?
Just a FYI…….I am not trying to be a smart AZZ or anything like that but , as a general rule the Ultrafire cells (especially the smaller sizes) have been proven many times by the people in this forum to be more or less junk and can be dangerous.
The internal resistance is usually pretty poor (high) among a number of other factors , such as a tiny cell wrapped in a larger casing to make the size right , with a wire connected to each end of the outer casing and packed with sand to make the weight right.
I would suggest getting some good name brand cells such as Samsung , Sony , Panasonic and such.
The protected or unprotected either one in a 50mm length will be fine and TK05. I would guess up to maybe 52 or 53 mm would still work ok , although it may start being a tight fit by then.
EDIT: I am thinking of the wrong light………51mm will probably be the max length on the TK05
High to Med is a 3 minute timed step down.
Just throwing in a bit more in the way of details. The big problem is the whole series of “xxxFire” names never got patented or copyrighted so there are any number of fly-by-night folks who make random cells of unknown quality and then they get wrapped with “whatever” name.
So in fact you can actually get decent cells with a xxxFire name on them, but the odds are NOT good and really it just isn’t worth the risk.
It depends on the driver and what is flashed into the programming. Some step down using a thermal sensor , others step down due to a timer and at the point that timer is set at (1 minute , 2 minutes etc….)
Most lights now also have low voltage protection , which is a sensor or sensors that will send a signal to the MCU which in turn will cut the power level to the driver as the cell or cells start getting lower on voltage. Usually around 3 volts as a medium is where the power starts dropping off and then 2.7 to around 2.9 volts is where the Low Voltage Protection will shut the light down completely.
The “fire” in the name for the most part people avoid. There are a few cells such as some of the Trustfire and Thorfire and Windyfire that come to mind right off , that are actually decent cells.
Timed step down to 80 lumens? Why would they do such a thing?
Learning, ever learning. It would be helpful if businesses would add “junk” in parentheses by their products. There’s just something about spending more for batteries and charger than for the flashlight that galls me (obviously, this isn’t a serious hobby of mine).
As far as their stand point I really cant answer that.
It is a dual cell capable driver though , so it is possible that could be part of it maybe?
The light does not get hot by the 3 minute mark but if it was running 5 minutes or more it would start getting pretty warm by then and be depleting the cell at a much faster rate due to the constant current driver trying to get more from less from the depleting cell.
Is there any way to tell, by looking at them, whether mine are good ?
Having dealt with a number of Thorfire products at this point, I’m pretty sure they control costs by using a number of the same drivers, switches, and programming arrangements for multiple light branches.
For example, the 1,000 Lumen 18650 based TK15S does start to warm up fairly quickly and a three minute timed step-down makes some sense (though personally I’d have gone for 4-5 min).
Take the same driver and switch and put it in the TK05 and you’ve reduced parts cost, but you have people scratching their head as to why the light runs like it does.
Rick,
I don’t know of any way just by looking at the cells to figure out their provenance or quality level.
The best thing I can suggest is to use them with a bit of caution, don’t just leave them sitting in a light long term, don’t run them all the way down, and use a good quality charger that will abort the charge if something isn’t right.
Personally, I also bought several ceramic tiles from Home Depot and all of my chargers sit on a ceramic tile as a bit of extra fire protection.
If you decide to dump them and get something else, I’ve been happy with the Jetbeam branded 14500 cells but there are a lot of others out there too.
No there is not unfortunately , but with them being the 14500 size Ultrafire , I would almost bet they are not very good quality.
If you already have a charger though you can get some decent cells without spending a fortune really.
Richard at Mountain Electronics sells the Windyfire 14500 for $2.99 each ($2.89 for 2 or more) and he is a great guy to deal with as so many here do.
They are Unprotected , but the light itself has built in Low voltage protection and will shut off when the cells start getting too low , so really the protection circuit on the cell is not needed in the end , unless it is just something you feel better about using.
http://www.mtnelectronics.com/index.php?route=product/product&path=59_87&product_id=477
So, two UltraFires and a cheap charger here. Not getting off to a good start.
I’m going to buy an 18650 flashlight (likely a Convoy S9) and a smaller, 14500 light to carry in my bag. It looks like I should be prepared to dump a good amount of $ in a good quality charger that does both (and good batteries, too, of course). Or just get lights that take alkalines (I know, heresy around here).
Will it say in the light’s description whether it has low-voltage protection?
Depending on what you want to start with really as to whether you spend “BIG” bucks or not………
A Nitecore D2 (will charge 1 or 2 cells) or Nitecore D4 (will charge from 1 to 4 cells) are both solid basic chargers that will handle NiMh/NiCd batteries in the – AA, AAA, AAAA, C, D sizes and also will handle the Li-ion cells from the 10340 size all the way up to 26650’s.
IMR batteries sells a lot of different chargers and they have both the above mentioned chargers , as well as a pretty big selection of batteries. Many times you can catch them having a sale and get pretty good prices on the batteries also.
The D2 is $15.00
Price: USD 15.99
and the D4 is $24.00
Nitecore Charger - Nitecore D4 4 Channel Digital Battery Charger
Average Rating: 5
Price: USD 24.99
