I have Mullvad and really like it. Servers all over the world that you can select from at 5 euro’s a month. I pay with paypal and it converts it to US dollars for me. I did a lot of research on VPN’s a while back. If I recall correctly:
NordVPN is extremly slow
Private Internet Access says they don’t keep logs but they recently had to prove in court that “don’t keep logs.” Apparently there is confusion on whether they do or don’t keep logs.
BlackVPN has a ton of fake reviews out there
Mullvad is more expensive, but it’s the most cost effective, fastest, no logging VPN I found. Plus the interface is super easy.
I’ve been using NordVPN for a couple of years with no issues.
I switched from Private Internet Access. I can’t even remember why I switched, but at the time it made sense and I’ve never had a problem with NordVPN.
I believe the hardware routers mentioned in this thread are the reverse of what you’re looking for. There are router manufacturers that have a VPN service, but it’s for connecting to your home network while away from home. What I assume you’re looking for is connecting from your home to the internet through a third party tunnel.
I’ve been getting great speeds with NordVPN: 125Mbps down, 25Mbps up but I’m having trouble connecting to Amazon.com which is really inconvenient for me. I had been looking at ExpressVPN as well. The only thing holding me back are the speeds.
That is usually the case but not always. The ASUS router line is a good case in pint.
Third-party open-source firmware exists (ASUS "Merlin") which includes a full-fledged OpenVPN client capable of storing 4 separate configurations. This firmware is so good that ASUS eventually started rolling some of its improvements into the factory firmware.
I am using a T-Mobile CellSpot 1900 (cause they were essentially free) flashed back to the ASUS stock model and then Merlin as a wired, dedicated VPN hardware appliance for PIA, sitting between the router and my computer. With the Broadcom chipset at 800 or 1000 MHz clock, you can get download throughput of about 90% rated speed up to 60 - 75 MBPS.
The caveat (for the beginner) is that the OpenVPN setup, while GUI-driven, is definitely not trivial. You may think it's working, until you discover you haven't taken protections to block non-VPN traffic or "out in the open" DNS requests including IPV6.
I’m using Nordvpn just over 1,5 year and there are times that none of their servers work or are really unreliable. In the beginning I had no problems with their servers but since they advertise all over the internet (and also Tv) theirs service went downhill. When my subscription ends I will definably pick an different VPN provider.
I use Mullvad, but it's not something I run full-time. Only for activities where I don't want to be tracked. They are very privacy minded, to the point that they will accept payments of cash shipped with the relevant account number, and apply the payment toward the account. Like, you could send 5 Euros in a plain white envelope with no return address and just write the account number inside it. (They also accept more traditional payment methods.) They have servers in the US and EU, and I haven't looked elsewhere. Using a nearby server, I don't lose any of the bandwidth I normally have from my ISP. They have useful setup guides on their website for various things, like OpenVPN on android, setting up a router VPN for your whole network, etc. I will note that certain services like hulu or Netflix will block the Mullvad IPs, this is because those services don't want to allow people to bypass region restrictions on content, and because the Mullvad proxy servers have relatively static, known external IPs.
i think i’m nearing the end of my 3 year Nordvpn deal, and i’ve never had speed or connecting issues. but… for certain games (where everything happens on the server and the game locks up when lagging) it’s not ideal, but i’m not sure any VPN is to be honest.
But that’s not what i use it for anyway… when my sub expires i’ll most likely get another x year deal from Nordvpn.
It’l probably differ from country to country how reliable a VPN service is too.
