Good tests, I like this last pictures, it is interesting how they have different visible tints, I would not of expected a yellow visible tint from a UV die.
Great data djozz. I believe your method gives excellent relative comparisons and that is probably most beneficial for most people here. It sounds like none of the leds you tested here failed as a result of your testing, is that correct? Too bad about the LZ1 but I’m still going to put it in something.
Here’s some pics of the BLF-348 with the Vishay led. Later I added a 10mm ZWB2 filter. I think that this led will be swapped again at some point.
The tiny pill with heavily trimmed and drilled ledboard, had to remove multiple shorts from led-pads to core by scraping the side of the dielectric layer.
The result. Later a ZWB2 filter was added.
A peek inside. You can already see why a OP reflector does not work: the OP texture is larger than the die!
The beam. The led was not perfectly centered but that would have hardly mattered here.
If I follow correctly, that triple Seoul Viosys Z5 with board package at KD is quite a deal. With discount code, it should come in under $14USD delivered. Now if someone would provide a C8 size UV filter (would like to swap the UV emitters into a C8F and use the base for a tube light).
Except that the optic does not have optimal UV-transmittance. I have no numbers but it is at least a lot worse than glass. If you loose 40% (I make this number up) because of crappy transmittance of the optic you loose the advantage of good leds.
If I would have a C8-size UV filter, I would make Sofirn C8F with these leds.
Hence the swap I mentioned. Good idea to mention that though. I was just thinking the 3 emitters alone for under $14 is a good deal. Plus you get a nice triple MCPCB and optic for other projects.
Thanks Steve, I’m not sure about the ‘invaluable’ though, UV led use is a pretty obscure corner of an already obscure hobby. Without these tests, I’m sure the world would keep spinning as usual.
Already got the quote in for 20 pieces of 2mmx40mm ZWB2 filter (fitting the C8), And I’m a bit double about it. They cost $9.50 each, with 50 dollar shipping. So that is an investment of $240 dollar which is not nice (I hoped for under 100).
On the other hand, if I could buy them for 12 dollar plus shipping (which is just $1.80 from my place to worldwide), I would buy 2 of them without hesitation.
So if I know beforehand that I would sell 17 of the 20 pieces, I would do it, but I doubt that there’s interest for 17 ?
Just to be sure about my reading skills. At this moment a black C8 with an LD1-driver with no modes (eh, 1 mode) is useless lying in a corner. Do you mean that without risk I can put in an LG UV-led from Simon?
Yes, you read it correct, provided that it is mounted on a DTP-board it will run in any direct drive situation with a single li-ion, so the LD1 should be fine. With the disclaimer of course that I do no testing on the lifetime of leds when driving them out of specifications.
Could anyone give me some driver ideas for a 3x SeoulViosys build?
I have simply no experience with UV lights, djozz’s filter was kind of an entrée. Now I sit on 3 LEDs from Kaidomain and a very nice Sofirn C8F host and try to figure which driver to build.
- mA
The spec for the SeoulViosys says 500mA but djozz’s test show they can cope with much more. But I’m not eager to use a FET/DD driver with this LEDs. Thinking more of a 7135 linear driver in the 2100-3500mA range at the moment. Too conservative or overkill already?
- modes
Are any modes useful or just single-mode? Or just no moon-mode? What about ramping, would you even properly see when you’re at low or high?
As I’m always ready to design a new oshpark driver from scratch for a certain light, I could very well make a, say, 17mm/9x7135/Attiny85 driver to get 3150mA and the latest fancy firmware. Any ideas?
I tend to want a simple user interface for a UV light, I have one with low-med-high (no memory) and I like it.
I plan to make the same light as you (C8F+SeoulViosys leds) and I think I will use a LD2 driver (I still have one in my spare driver box, but l4p does not have it for sale anymore) so that 2A per led which sounds quite optimal to me.
