Maybe have a look at the Haikelite SC01 .I don’t have one but 2000lm turbo from XHP35 Hi,with thermal regulation,26650 with usb charging,135mm long,40mm head,under. $35.Anyone know more about it?
Similar but quite some difference, (measurements in the OP) out of the four lights UT02 has the widest head (59mm) and D1S has the smallest (50mm)
Also the same with the length (UT02 longest, D1S shortest)
I do realize these are not quite pants pocket sized lights, was thinking more of jacket/vest side pocket. So basically which of the lights fits smaller in the hand for that. The D1S seems to be a good bit smaller overall.
True about the battery capacity for extended run-time, and the D1S does kind of look odd or unbalanced, the short thin tube with the large 50mm head.
I’m going to have to look to some reviews to find actual kcd measurements, what benefit for a nearly a 10mm wider head if the throw distance is slightly less, not more?
So now I need to find some actual measurements of the others too.
Not that it matters a lot but I find it to be unappealing in looks, uglier than D1S I think. :confounded:
I’ve got them both with same emitter option. 4000k I like them both. I haven’t had the time of late to run the numbers and do my comparison shots but when I had them both out to the lake a very cold night not long ago, it looked like the D1S out threw the M8 slightly. However the M8 did not get nearly as hot like the D1S did which was nice. If that’s due to a weaker thermal path, or simply the larger mass of the M8 we’ll see. I like the 26650 size and cell options for run times vs the D1S. The UI of the D1S seems more polished than the UI of the M8 also, but I have plans on doing some stuff to the M8 to make it more to my liking.
Just throwing my 2cents in the mix regarding my feelings towards both of those options.
The Maeerxu M8 is nice. Neutral tint, lighted side switch, on board usb, high quality machining. Some think the Maeerxu might be made in the same factory as the Emisar lights. I don’t doubt it for a minute. Materials are virtually the same, build, and anodizing is very similar. Even the thread shape and pitch is identical.
I do not have ut02 but I have u21 and I never want this flashlight again. the driver and switch quality is very poor, ut02 probably has the same components
Yeah forgot about the switch it’s a real POS on the UT02 has a little metal cup, and it was taped in place with what looks to be a piece of Kapton tape, lose the little cup, lose the switch. I replaced all of my UT02 switches because of it.
Thanks Pierre & Robert, finally some feedback here on the M8!
The M8 size is right between the D1S and UT02. So it’s form is closest to a DS1 but with 26650 :+1: …It’s a nice looking light too!
I really like the upcoming green color version (was suppose to become available on Mar 31 but now it’s pushed back to April 11)
What made me lean away from it was the UI. It has ramping only? And I read the ramping is too slow? I need to know more about the UI but I just re read everything I could find in the M8 thread and maybe it’s not so bad…
(All quotes taken from the Maeexu M8 thread: ENEDED)
Questions about the UI:
Does it have memory of the last used level in ramping?
Ramping takes 6 sec. from lowest to highest?
Some things I like:
1 click ON - click again OFF :+1: (but that only is to the lowest brightness level? Not memorized level?)
Thanks, yes it’s already under consideration (please see list in the OP)
Although it’s the highest price light on my list even with the discount, Thrunite quality is Excellent (with a capital E!)
I’m a proud owner of the TC20 :+1: :+1:
And it’s a whopping 1.6 cm shorter than UT02 (same head size) .…but CW ONLY! EDIT: NW is now available!! :+1:
Decision getting tougher! All 4 good are lights, performance appears similar.
Deciding Factors are now:
Size
Price
UI
Emitter tint
Extra Features
Look and feel
Some more thoughts:
D1S It’s the smallest, high quality, great UI, 4000K tint, but lowest battery capacity and ugliest.
UT02 Has lots of features, 4332K tint (measured by komeko) good modding potential. But the largest size and could have switch issues.
Catapult V6 High quality, highest lumen output, EXCELLENT UI (same as Thrunite TC20 :heart_eyes: )
Maeexu M8 It’s the next to smallest size, great quality, lots of features, 4000K tint, lowest price that’s almost too good to pass up. But it has a tight tube so some cells wont fit. Also the UI is somewhat lacking.
Thanks, that’s a good point… I’m sure Thrunite won’t use an extremely cold (blue)CW tint. EDIT: NW option is also available now.
And can we expect the same? TN40 is XP-L HI, Catapult is XHP35 HI.
That’s right I read that but forgot. Same as with UT01 5000K
So all these lights are around 4000K (Not sure the CCT for the NW Catapult V6)
I don’t really care for the colder end of NW (5300K-5700K) I’ve always like right around 5000K (not too yellow) I’ve only recently begin to like the warmer end of NW (4000K) but now I’m wondering could that be too warm for a thrower light?
Although in my eyes trying to see distant objects in the colder beam tint is worse, because its “white wash” effect.
Ya, the c8 with the dedomed xpg2 has a tight beam. But once you shine it 100+ yards it starts to open up nicely. Putting a lot of light on target. I know your looking for a e switch light. But another option for a clicky light would be the convoy l2, with whatever emitter you want and fet driver. The new sst40 sliced would probably go great inside it. I have one I’m about to put a dedomed Xpl v6 1a. With a 6 am buck driver. I’m keeping mine in the 2 cell configuration. But I want to get another to have for 1 cell. Jacket pocket light or travel with. Hate to admit I’m slowing down until some new emitters or drivers etc or just a light I can’t turn down pops up. I have so many now I could never use them all. So now I’m a lot more picky then I use to be. Usually build what I want now. I use 10 at a time sometimes at the park to light it up.
Not just theory in my real world use it is. If you have any humidity or mist etc the cool white reflects back at you a lot more. Way more. If you have a environment with clear nights not a issue. The other thing is detail. It’s a lot easier to my eyes to make out things at distance with a warmer tint. The colors come out better. Also I’ve noticed that bugs are attracted to cool white lights more then neutral lights. But I still use both. I prefer neutral but I still use my cool white lights
I have to say I do like my high cri thrower. C8 with 90+ cri 5000k 219c. People said it would blow with a fet driver with spring bypasses. It works just fine. It just gets really hot after a few minutes. I usually keep laptop pulls in it. But I’ve ran 20 amp cells on turbo no problem. Has a nice beam it’s very similar to a xpg2 dome on in a c8
