ENEDED
Please send me details too.
If like to know of the GB is still open and what the pricing is like.
Thanks !
Interested. MM18III Depending on price. Thank you.
Deal is still available.
Interested. MM18JR Depending on price. Thank you.
Done. [quote=demonnov] Interested. MM18JR Depending on price. Thank you. [/quote]
Has anyone received the other two models yet?
My MM18JR is currently stuck in German customs, let’s see when it goes on! :frowning: Before, nothing happened long ago, they are not the fastest!
Did you opt for standard airmail or expedited?
I had standard airmail. With DHL express ($ 25) I could have bought them at Banggood.
There was not another option.
I am interested.
My MM18JR and the BK-FA30S are at Germany customs too. I ordered via standard Airmail too.
Thank you freeme. I order MM18III $154 / 1 piece send by register air mail
Got mine today.
The reflector has some marks, the LED is far from centred. :frowning:
I tried the rear button and I get a green/red blinking when pressed. When pressed again it stops the blinking.
But the light does not turn on with the main button, not even a sign of life form what is meant to be the battery indicator in the centre of the button. Am I missing something?
Interested
Definitely a sad thing to hear.
I’m waiting for mine to arrive
Bruno28, can you post some pictures of the LED and reflector?
Mine still stuck at somewhere in airport I guess.
Interested in the BK-FA30S
So I managed to dismantle a bit and see what the issue was. No idea what it was, but when I put it back together it started working.
But mode 4 and 5 has massive flicker. And it actually doesn’t change mode as its somehow interrupting the mode change, even to turn on and off. Its almost like I have to keep trying until I get the perfect timing where there is no interruption for it to work. The battery level light in the middle of the switch also flickers.
So mode 4 and 5 are completely not possible to use on my light. So I programmed one button as lowest output and the other as highest, and that allows me to exit when stuck on mode 4 and 5.
Here is the link to reflector photos and LED centering:
https://www.dropbox.com/sh/4lxbelsy5042imp/AAAmirSOLgl_rJN73fAAB5U6a?dl=0
Videos of flicker:
https://www.youtube.com/edit?o=U&video_id=SGD61OZMaWI
I did a run test on turbo, and the flashlight reached 72 degrees C. Never stepped down.
Interested in all 3 if still available.
The rear button is not the power switch for the main light. I believe it is meant for signal purpose , or act as a flashlight location beacon?
