Bugger. Arriving the 16th-20th…
Are these the ones you guys bought?
https://www.amazon.com/EBL-Li-ion-Rechargeable-Batteries-Flashlight/dp/B06WWP62NP
EDIT: My very first 18650s were EBLs. I bought them (with a charger) with an el-cheapo’ Ebay C8 head set— still working great after 6 years). They run today about 70% what they originally did (after being mostly sitting at 70% charge). But looking around lately as a flashaholic, I thought of them to be a decent, no frills option that maybe got within 80% of the advertised rating- on a good day.
So if these are HITTING spec- I’m buying a set!
Lightbringer… you’ll have to let us know how you do here after you run a few of these 14500s through one of your: almighty, bad-ass, wiz-bang battery torture devices.
That’s the one.
Yeh, will put them through the wringer for a bit just to see how they fare.
If a cell’s capacity is as advertised , does that generally mean they are safe ?
I’m a bit new to this world but here’s my opinion.
If a company states a capacity and produces a product that matches those claims, it goes a long way to establish credibility. If they advertise something much higher but can’t deliver, then to me that already makes me wonder about what other claims they’re inflating or misrepresenting.
There’s also a factor of being realistic, if a capacity doesn’t seem to line up with competitors, there needs to be a good reason it’s so much better or worse. If 10 other manufacturers are making 14500 cells with similar dimensions and similar capacities, then there’s also more credibility that this product is at least within a good working range. The outliers worry me because if it sounds too good to be true, it usually is.
Apart from this, in my research you really don’t know until someone takes these cells apart. You can do a exterior visual inspection to get an idea, but there are ways to hide flaws, and that still doesn’t tell you a whole lot about how something is made on the inside.
Or… we let Lightbringer blow up one of his chargers— that’s easier
Hey, and welcome to BLF e1000! Lots of smart dudes (and a few like me missing fingers/eyes) here to learn from.
Thanks for the welcome! Does seem like a lot of smart people, I hope to contribute. Hey if you’re still posting then you’ve got at least 1 more test left in ya!
Just got ’em today, will wring them out tonight to see how they fare.
Maybe longer, if I go through some “refresh” cycles.
Wow… they must have been shipped from across the street— that was fast!
Eagerly waiting for your report
Quite likely from the same OEM under the wraps of Soshine 14500 900mAh and Nicjoy 14500 850mAh cells. After all, how many OEMs in the world are producing li-ions in this format and capacity range?
Good for up to ≈2A, 3A at most.
Kudos to the rating chosen by EBL.
Cheers :-)
Yeh, I tried getting the Shoshines, but shipping was obscene (and cumulative). Tried Sofirn, but they ostensibly can’t be shipped to the US. So tried these EBLs.
Look nice in the SP10As I got today, will torture a few tonight, see how they hold up. If well, will probably order another batch while the getting’s good.
Ain’t gonna be using anything more than a coupla amps in any 14500 light anyway, so I’m okay with that.
Which is probably what Sanyo UR14500P is good for as well, but at a much higher price.
I’d buy them if I had more use for 14500 cells. I typically prefer to just run NiMH cells in my single AA lights.
That is the battery I run (but I’d never pay $7 a pop for one— got lucky and stole it off eBay on a slow auction for $2.40 shipped!)
I ALSO did order the Soshine 4 pack (retail) still coming— it was hard to drop $10, but shipping was (somehow) 10 cents, so I did it. But if Barkuti is right (and he always is), then I’m also dropping an order for two sets— before they are gone.
Give us some good news Lightbringer!!!
They’re an Amazon Prime eligible item, and although not the best in the industry, Amazon return policies are pretty good.
Edit: BTW, I also bought the 18650’s and 26650’s for fun. The 26650’s are being used in a 2D maglite conversion and work well.
… But if Barkuti is right (and he always is), …
Dunno dafuq has happened to GearBest but at least for me the shipping rates have somewhat increased, massively and namely for cells which usually kills the deal. By the way.
Cheers ^:)
Here, too. Tried ordering 14500s from GB but shipping killed the deal. Hence the EBLs from Amazon.
Ordered 8 more BT 30Qs from FT, ’cause 1) GB doesn’t list BTs, and 2) shipping is likely to be prohibitive, too.
So rather than ordering the wraps, tops, etc., from FT and the cells from GB, I just ordered the complete BTs directly from FT, with <2bux shipping! And price was comparable to GB.
Wellp, one’s loss is another’s gain… whaddya gonna do.
Pk cell 14500’s are a decent low cost cell, from alixexpess.
very conservatively rated at 750mah.
i have seen several hit around 840@1a
Did a 4-pak in my Ope… talk about cutting it close!
500mA up and down, 4 cells clocked in at:
801mAH, 801mAH, 817mAH, 800mAH.
All arrived at about 3.7V.
KICK ARSE!!! I’m ordering two sets NOW!
You ARE truly the “Battery Dude” Lightbringer :+1:
