BLF GT (preliminary) modding thread
Wow! I’m very interested in a TA GT XHP70.2 driver when they’re available. :+1:
Forgive my ignorance, but I’m having difficulty understanding all of the modifications needed to get the 70.2 into the GT.
Do the battery carriers require modification? Does the 70.2 need a new MCPCB or can it be reflowed onto the GT’s stock 35 board?
Thanks, Texas_Ace!
It will need the Driver, MCPCB, XHP70.2 LED itself and Centering ring.
The stress test I ran was to see if the carrier springs could handle the power and they passed, although they were pretty warm at the end of the test.
I am working on getting the mcpcb’s made and getting them sold but it has been a hard sell for lumintop and they have still not given me an answer. If they don’t sinkpad makes an mcpcb that will work with some sanding/filing although it is not quite as nice.
TA, Where did you get the GT centering rings for the XHP70.2?
Thanks for the explanation.
I hope Lumintop gets on board after seeing some photos of your 70.2 protos… :slight_smile:
I 3D printed them :wink:
I actually printed a bunch of different sizes since the height plays a big role in the focus. Around 2.5mm saw the highest lux but it also has a dark spot in the middle at longer ranges. By going up to ~4-4.5mm it removes the dark spot with minor effects on the lux.
Yes, I am hoping they do as well, if these numbers hold up I am guessing they will, even I am shocked at these numbers if they are real.
I would not believe them if I had not seen them myself and I still doubt.
I am interested on the MCPCB with 70.2
I am interested in modding my GT with a 70.2. I will purchase the parts if they are made available…
Guys, how hard is to replace bottom part of GT, where battery tube goes in?
Mine is broken, Lumintop offered that they can repair that or I can do it by myself.
Mike
Well, it is very simple, you just unscrew the head and then screw it back on the new light engine.
The hard part is getting the head off. You will need a strap wrench almost assuredly. I was able to get one apart without a lot of hassle by loosening the bezel first and then the head. I carefully clamped the light engine in a vice to do this.
some are much harder to open though.
I would try opening it first and see what happens.
I noticed on CPF that Vinh is in the process of modding a BLF GT.
His modded one will use XHP 35 HI emitters arranged in 18 quads … 72 emitters total! :+1:
Vinh’s 72x XHP35 HI BLF GT
I guess he is bored with CFT90 mod now.
He’s said before he cares more about lumens than throw.
My prediction is that is going to cost around $20 per emitter… :open_mouth:
He says reflectors waste too much light outside hotspot, so he likes tir. That could be why he choose not wasting lumens over throw, but i think he likes throw, so he must build massive world record flashlight output of lumens in order for tir to throw as much as it can.
I don’t think it will be lower than $30 per led. His goal for Sirius is 80000lumens and 600kcd.
These pictures may help.
Post 61 had some more pictures.
Well, My dr meter showed up today and I was able to get some readings of the XHP70.2 GT’s along with some crude beamshots. I will post the results tomorrow but I will just say I am not disappointed in the slightest.
Do you have a stock gt to compare pictures with? Can’t wait. Real lookin forward to hearing and seeing the results.
Good, good! Looking forward to the beamshots and measured throw data.
I’m quite happy with my GT but to be honest - a light this big could have some somer POWERRRRR………………. 8) 8) :sunglasses:
I thought about giving it more throw (for instance a black flat) but the tiny beam of few lumens out of a light this big, I don’t know :question:
Cheers
Nico
Ok, here are the results of my testing with the Dr Meter LX1330B lux meter and the XHP70.2 GT.
These readings are at 10m, outside.
First the stock GT for a reference point.
- 1.1 Mcd for a total of 2100m of throw
Next up is the XHP70.2 80cri GT with dome on
- 560 Kcd for a total of 1500m of throw with over 9,000 lumens!
Lastly the XHP70.2 80cri GT with sliced dome
- 750 Kcd for a total of 1725m of throw with over 9,000 lumens!
So needless to say I am pretty happy with the results. A P2 bin XHP70.2 could most likely get a bit more then this but I didn’t have any on hand when I put these together.
Here are some very crude beam shots that kind of show the difference.
Dome on > Dome sliced > Stock GT
Stock GT:
XHP70.2 sliced Dome GT
XHP70.2 dome on GT
I am officially listing both of these lights for sale and I can swap the LED to something else if someone wanted.
I will post a thread for them later when I have some time.
