Vapcell NCR20650 3000mAh (Purple)
Official specifications:
Model: NCR20650
Nominal voltage: 3.6V
End-of-charge voltage: 4.20V
End-of-discharge Voltage: 2.50V
Typical Capacity: 3000mAh (0.2C discharge)
Min capacity: 2900mAh (0.2C discharge)
Weight: Max:56g
Internal resistance: Max:10mOhm
Standard Charge: 2000mA,CCCV 100mA cut-off
Charging Time: 3hours(standard charge)
Quick Charge Current: 4000mA
Max Continuous Discharge Current: 30000mA
Operating Temperature: Charging: 0°C ~ 45°C, Discharging: –20°C~70°C
Storage: Temperature –5°C~35°C, Humidity <75%RH
Standard environmental condition: Temperature: 23±5°C
Humidity: 45-75%RH
A 20650 cell, this means slightly larger diameter than 18650, but same length. This cell is a high current cell with good capacity.
The discharge curves looks nice, nearly constant capacity at any current.
At high current the cell do get warm, here I had to stop the discharge due to temperature.
Conclusion
This is a good high current cell with fairly decent capacity, in performance it is close to the best 18650 cells.
Notes and links
The batteries was supplied by Vapcell for review.
Compare to 18650 and other batteries
