Funny how similar this is to Sound pressure meters and respective frequencies. I have been in audio for decades and this discussion is almost word for word the same.
The difference being sound meters all come with the response curves and different weighting for relevance in different environments. The color spectrum might be a little more complicated.
Thnx Djozz. Its bin a while since I did cd measurements. But I believe I am doing something wrong. I use the rapid tables converter for lux to cd. But for instance when I fill in the Ā± 1400lux of your Mitko thrower at 7m, I get 69 kcd, wich should be much higher.
Probably having a brainfart, can someone help me out. :weary:
No, nothing wrong with your calculations, none of the flashlights that I used for these tests were at maximum modes, but on a well regulated lower mode to obtain a flat output.
Thnx! Guess my mind can only think in max lumens and max kcd. Thanks again for the test. I only have the uni-t, but I also find it to measure 10%+ to low.
Youāre welcome. It isnāt invaluable to me either, I just find this measuring stuff lots of fun, especially when antique optical instruments can be used
The newprices for the meters at the time I bought them were:
MobiLux Class A : 1400 dollar (but bought 2nd hand)
Tasi 632A: 135 dollar
LX-1330B: 27 dollar
Tondaj LX-1010B: 22 dollar
Uni-T UT383: 12 dollar
It is good to hear that my struggles are not unique
Yes, there are complications in light measuring that are probably not present in measuring sound (but I have never been into measuring sound, it will for sure have its own pecularities). So much that an overall measurement error of 10% is already considered very good. What does not help is that even the most expensive luxmeters do not come with detailed wavelength/response data, if you are lucky you get a maximum overall error for that and thatās it.
And with the way we use luxmeters we do not even have to deal with how different luxmeters respond different to the incoming angle of the light, because with throw measurements the angle is always close to zero.
Great tests Djozz! Iām glad I found that TASI632. Now Iām more confident with all my measurements. This is a lux meter with decent accuracy across the full visible spectrum without breaking the bank.
I played with a DIY crude goniometer using my TASI632 but Iāll need to make new slit hole to it. 1mm seems to large for close range input.
What I did find out with the Tasi meter is if you measure at the very low end, under 10 lux, the reading gets inaccurate by static charge or capacitance or whatever something on the cable between meter and sensor, it can give an off-set error as large as 1.5 lux. If part the cable is resting on a metal surface (in my case the chunky monochromator) that error is gone.
Correct!
Never measure anything under 1 lux near metal objects and electronic devices placed close to the cable. When the USB connected, it will also adds ~1 lux to the measurements. And try not to move the cable after zeroing. Itās not EMI shielded.
You did notice correctly that cheap meters especially struggle with measuring dedomed emitter spectra correctly.
But it depends entirely on how nerdish you are on the numbers, are you prepared to spend 5 times more money to gain a couple of percents more accuracy?
TASI632A also equipped with USB output for easier runtime measurement via PC/laptop with OEM software.
Check Djozz thread about it here: Tasi 632A luxmeter, some tests
Of course if you cleverly combine colour filters you will influence the wavelength response. My first thought is also: how hard can it be, but I donāt know why, but making the colour filter really right it appears difficult and expensive, that tiny filter is the most expensive bit of a good luxmeter.
I have a generic light meter with a LX-1330B and i also have the UNI-T UT383BT. The Bluetooth edition and they read within a few lux of each other the UNI-T seems to read lower on most lights.
Thanks for another very informative test. If the covers between any of the units (especially the Tasi and Uni-T) could be swapped, it could be very informative to remeasure both to see if and how the results change.
Someone just did another āpost - deleteā action?? I hate when people do this.
I got the notification, saw his early post. Then another notification brought me to the āpage not foundā. Checked and he already deleted all his last two replies.
