Eventually received my Seoul Viosys emitters so some DQG UV mini goodness today :)
Upgraded my DQG Hobi Ti+ UV keyring light
Seoul Viosys Z5 series, 365nm UV LED, CUN66A1B
10mm sinkpad soldered to brass pill
Ground down 11mm ZWB2 filter
Direct drive, single mode
10180 cell
2 x 6mm x 1.5mm green tritium vials
Magnetic detachable tail unit
USB rechargeable
DQG petrol lighter
Max current 600mASeoul Viosys UV on some currency. Shows up all the UV fluorescing bits nicely :THUMBS-UP: Some UV light comparisonsdjozz UV Emitter Tests
DQG Slim AA UV - Stainless Steel
Noctigon MCPCB
Hand made copper pill
Ground down 15mm ZWB2 filter
3x7135 driver, single mode
Reflectored
14250 Cell
Lighted reverse clicky switch
Max current 1000mA
DQG Hobi Ti UV
10mm SinkPad MCPCB soldered to
Hand made brass pill
10180 cell
Twisty Switch
Max current 600mA
What did you do? That doesn’t even look real. If I zoom in a bit it looks better, but the texture at both ends seems like something which shouldn’t actually exist.
Happy to have this thing fire up on my first try. There’s a few small tweaks I still want to make but happy with my first day progress. I’ll save the pics since everyone here’s seen a S2 and my soldering skills are HORRENDOUS.
Yeah, due to the low Vf, there is a high potential for FET-based drivers to turn single 219c emitters into smoke when used with a high-amp cell. It might be a good idea to use a weaker cell there, or use thin wires to feed the emitters, as well as un-bypassing the spring(s).
An old NCR18650A would probably be safe, if you can find one.
Another take on the DQG Slim Ti extension tube lights I've been liking so much lately :)
Samsung LH351D 4000K 90 CRI
KD DTP MCPCB
Sanded down reflector
FET 15mm driver with guppydrv3 firmware
Thermally controlled
Hand made copper pill & switch housing
Titanium body
14500/ 14250 cell compatible
Magnetic tail (19, 2mm x 2mm magnets)
Metal Switch
Reverse clicky
Max current 4A from Sanyo UR14500P
Around 924lm OTF14250 version
Added a lighted tail to an EagleEye X2R (with stock driver). First tried without bleeder resistor on the driver and 2x 4.7 kOhm on the tail board (the 6 tail leds are parallel with a common resistor before each set of 3), but that resulted in next mode memory (the driver interprets any length of ‘off’ as going to the next mode). Then I tried 2x 8.9 kOhm, and then 2x 22 kOhm. Still next mode memory. Then I added a 680 Ohm bleeder on the driver (between batt+ and ground) and all was well: last mode memory and a well lighted tail.
