Yep, this is a very wise idea. I did this same thing and I have 2 lights I use to double check my sphere on a regular basis and a bunch more written down for more in depth tests.
The biggest issue I have had with readings changing over time is dust, it will collect and lower the readings naturally.
Ok, I am sorry to report that I made a mistake in the order and it will take a week or so to get the correct parts.
Long story short, they do not have a 4” to 1.5” reducer so I had to use a 4” to 2” and then a 2” to 1.5”.
I had 2” on the brain and ended up having to place the order over the phone due to some website issues at the time and I mistakenly ordered 3” to 2” reducers for the 3” spheres instead of 3” to 1.5”.
I also totally forgot to order the 2” to 1.5” reducers.
So I am placing an order for the missing parts this weekend and I expect them to ship on Monday. Last time they arrived on Friday so I expect the same this time.
In the mean time I am preparing all the other parts and using some pieces I got from home depot to do an initial calibration of the spheres.
This should make it fairly quick once the missing parts show up. I am hoping to make my 4 week deadline I set for myself.
Today I got the family involved and we got a fair amount done in preparation for the real work. Hoping to start really digging into them tomorrow.
I will keep ya’ll updated.
I can say that I will NOT be selling any more of these for this price again.
Just got the order placed for the missing parts, they say delivery is expected Friday.
I got a payment earlier today for a sphere but there was no user name on the payment. Could whoever sent the payment please reply to the PM I sent you so I know who it is from? Thanks.
Ok, almost a week and countless hours of work later and I officially have the first sphere calibrated and put together!
It has been way more work then I planned on to get these sorted out. I went through a dozen different options to get these sorted out but in the end it is just a matter of trial and error on each sphere.
All the parts are here now.
So the next several days are me putting together a bunch of spheres and calibrating them.
On the plus side they are matching mine very nicely once calibrated. Looking like I will be able to be well within the 5% tolerance range I was hoping for, I am aiming for 3% between spheres. Getting closer then that is very difficult as even details like how hard the pvc is pressed together comes into play at that point.
Also just so everyone knows, I had to raise the prices on the spheres for new orders, after calculating all the costs involved both monetary and time, the existing prices were just not worth it.
For example I just had to spend $60 to buy boxes to ship these in, on top of the shipping costs being a lot higher then planned. The little things add up quick.
Not to mention the time involved, it is taking around ~2-3 man hours per sphere start to finish to get these ready, that is of course if you don’t factor in the 6 months I spent setting up my own sphere to get the design and calibration.
The new prices are:
3.5” - $135 + $17 S&H in cont US
4.5” - $200 + $25 S&H in cont US
I will be putting up any that are left over on ebay for $150 + shipping and $225 + shipping respectively to cover the ebay fees.
Now since I did not give any warning on the price increase, anyone that wants one today I will honor the old price.
Thanks, I will let you know when I get to shipping them. Thus far just been going off general calculations, things are usually a bit different once you ship the real things (sadly usually higher).
I am still working on the spheres, had to change the way I was doing them a few times, so you will notice that the centering rings were painted silver as an attempt to make it look better then the reflective tape, but that didn’t work lol.
End results are I now have about 15 spheres mostly ready, just have to double check them and then glue them together. We are tripping over spheres in the living room lol.
I am hoping to start shipping early next week if all goes well.
After a lot of work they are lining up with my own sphere quite well.
Thanks for all the hardwork. Even with the new pricing, it is still a good value. Now forum members around the world have a standardized method for comparing their flashlight brightness with other flashlight enthusiasts.
Ok, after a solid day of work on these spheres I have 12 finished, in boxes and ready to ship.
About half of the remaining 3” spheres are done with the “1st stage assembly” and another half is done with the “2nd stage”. It is complicated, way way more complicated then I planned on. Each and every sphere has to be calibrated individually sharing very little of the process with the others.
I was really hoping to have a “recipe” for them that would get me within 5-10% and then just fine tune from there but that is not the case at all and for the life of me I can not explain it. I tried to figure it out for a whole day earlier this week and just got frustrated lol.
Could some of the problem be that white PVC pipe isn’t made for reflecting light and therefore the illumination tolerances across tubes are not uniform. Not that you can’t make an accurate lumen measuring device out of one, just that across materials non-uniformities can create the need for the calibrating you are describing. Sure they all look perfect white to the eye inside, but I wonder if the inside surface of the pipes are optically dissimilar in small but significant ways.
It won’t matter for the final product, as you are calibrating them, but as you mentioned…takes more work than to just slap them together…
Interesting finding on your part. Curious how singular lumen tubes made by people can compare with each other’s.
At least your batch will all be giving similar readings to all the people that bought yours—a true standard!
This is quite probable. As 2 seemingly identical pipes can have slightly different readings. In some cases the ones that you would swear should ready higher will actually read lower and vice versa. I have given up on figuring out any rhyme or reason and just go at each one by trial and error until I get it dialed in.
You bring up a point that leads to a pet peeve of mine actually when it comes to lumen numbers posted in the flashlight world in general.
Anytime I see something like “light A made 846 lumens” I just laugh, there is no way in heck that a DIY sphere is anywhere close to accurate enough for that kind of reading. Some are better then others but even the best I would not put better then 10-20%.
Technically all Cree LED’s we use have a 14% tolerance from cree, meaning that no sphere can be more accurate then that. The flashlight driver/batteries ect add even more variance issues on top of that.
This is why you virtually never see exact lumen numbers from me, I always round them (usually down). I like my sphere and I think I have it reasonably well calibrated but I am under no delusions that it is still a DIY home made PVC version of a $10k sphere. These are NOT precision devices.
I would recommend and ask that people using these also round the numbers so as not to give the allusion that these are more accurate then they are. Posting exact numbers down to the single digit makes people think you can actually get a reading down to the single digit.
So back to the original question, from the comparisons I have made and looking at others (My and Djozz talked about this a few years ago) the DIY spheres you see in the community vary widely. 15-40% variance is common from sphere to sphere.
A lot of this comes down to calibration method, flashlights are simply not a remotely good way to calibrate a sphere, you have to take hundreds of readings and average them out to get something even close to a reasonable calibration. That assumes you can trust the manufactures ratings in the first place (which unless they measure each and every light, still has a 14% tolerance for the LED itself).
LED data sheets are much more consistent since Cree has a big motivation to get the numbers right but still have a 14% tolerance range built in.
So in the case of these spheres, I calibrated them with LED datasheets, this means at the very best they can be ~14% accurate to actual lumens since that is the tolerances on the LED’s themselves. The end result can not be better then the calibration method. That is simply how things work. This is why professional calibration LED’s cost thousands of dollars.
I would add a few more percent to that range as naturally there are more tolerances to take into account besides the LED’s themselves, such as heat, power supply variations ect.
Now consistency is another item altogether and that is much much better. People like to confuse consistency and accuracy. On my sphere I have a few “standard” lights that I will regularly check the output on (the same lights I am calibrating the new spheres with) and over time excluding dust build up, I get maybe a 1-3% variance at most (although I would officially rate it at ~5%). This is mostly due to the atmospheric conditions like humidity and such.
The spheres themselves seem to be coming out to well within ~3-4% on initial calibration compared to each other here. Figure that needs to be widened some once the post offices gets done with them and they are put back together but still very comparable. So the most important thing is the consistency between them as you said.
I just don’t want anyone being under the delusions that these are precision instruments. For that you will need to spend 100x the price.
Years ago when I was researching building one of these I recall people were painting the insides with flat white spray paint, I wonder if this was the reason for doing it?
There are many different shades of white spray paint as well as finishes (low gloss, high gloss, flat, semi flat, etc…) and the humidity and temperature that it’s painted in can effect the finish (various degrees of flat). So there’s probably just as many variables, if not more, that just leaving the pipe stock.
When I was considering building my own, I was thinking of scuffing up the interior with Scotch-Brite pads to get both a more uniform level of reflectivity as well as more uniform color. That’s fine for a one-off build, but too much work for TA to do on a bunch of lumen tubes.
In order to get a consistently reflective finish, professional integrating spheres use a coating of barium sulfate (BaSO4). Using this in TA’s lumen tubes would be completely impractical, though. It would be a lot of extra work and money and probably not give any improvements.
This was one of the many things that I tried to figure things out. I tried both white and silver but painting the inside actually made things worse in my case so I gave that up pretty quick.
Most of the variations are rather small in the sense it is only a few lumens one way or the other but I like things to be done to a high level so that annoys me.
I would suspect trying to identically spray paint the insides would be more of a challenge than just adjusting for the factory finishes of the PVC pipes.
