We both got our GT in early March and they travelled together according to changes in tracking had only few minutes differences between the two lights. So I think they are same manufacturing batch got not so throwy. I need to get a strap wrench or something and then try focusing.
I managed to open my GT head with a leather belt
I printed out Enderman’s focus checking circles with the 3 square. I have still my friend’s GT too so I checked both. Mine was good for about 1m distance and then started to seem over focused. The 3 square moved to the center. At 7-8m the 3 squares almost completely overlapping each other. That is why I got the biggest numbers at 10m because it was focused around that distence. My friend’s GT was even worse. As we seen in the intensity numbers too. So I need to sand the centering plate thinner. I needed to go to work so tomorrow I will measure centering plate thickness and sand it down a little.
you don’t see it on a beamshot. Maybe with the focusing templates you can see the squares but with naked eye I don’t think so. But I will try to make photos.
I can try but you will don’t see much I think. These are not huge differences just hunting for the perfection. If I can manage to focus better and make 1100 kcd from my 980 kcd it is not what you can notice in a few meter wall beamshot.
Just tell us if sanding down the centerpiece improves the hotspot at larger distances. Especially if it can remove the corona and make the center brighter.
I have some results! My theory was a bit wrong. The centering plastic wasn’t too thick. It was thin. I sanded down from 2,5mm to 2,33mm and it made worse. I only got 874 kcd from the stock 980. So I started placing kapton tape stripes to the bottom and about every 0,1-0,15mm added I reassembled the head and went outside to measure lux at 10, 15, 20, 25m.
Today’s last result was 1100000 cd at 20m with 3,17mm thick centering plastic. This is not the end and I have pics and a lot of numbers. The interesting that as it was getting better the highest number moved to the bigger measuring distances which I think is good because the beam is more parallel and forming the hot spot farther is good. Tomorrow I have a lot to do but I think I will add some more tape under that centering piece and I want to find the best focus setting. And I will post all the pics and numbers when Im done.
Stay tuned!
The latest batch of reflectors was made by another company (which is why there was no shipping delay this time). It is possible that the focal length has been changed slightly. It would line up well with the XHP70.2 I built.
I used a 4.25mm centering ring on the first light I built and it had no dark spot but it took almost 5mm to get the same results with the new one.
Plastic shims for under or on top of the centering block. Mine is shimmed at 3mm thick overall, my other GT’s reflector was better so I swapped them. Dark hole in the beam 3.5-4ft. off the wall.
Today I went up to 3,42mm centering piece thickness and got 1174500 cd.
but the hot spot started washing out so I think the optimal thickness is between the 3,17mm and 3,42mm. Now I need to sleep so I will try the last steps a few days later when I have more time.
Do you have a donut hole in the beam or not? I hat a visible donut hole when I placed shims under the centering plate. It was visible even at 250m distances
Luckily I have my friend’s GT in my hand so I will try focusing that too. That was even worse stock than mine. It only got 894000 cd. Now I have two workdays so I don’t have time for it but after that I will upload all results.
EDIT: I talked another hungarian forum member and he will send me his GT head too to measure it and focus it. So I will have 3 GT focus tests but all 3 is from the late February or early March batch because they all had same tracking movements around few minute differences.
I spend one morning messing with the center piece of my GT, made it both thinner and thicker, but never got rid of the slight donut hole, and the throw did not get better. I may have to look more precisely, but I first have to replace the ledboard screws with version that do not have a very round head but heads with a straight side, so that the center piece can be positioned exactly and keep the led in focus. But it takes too much time already, I will first wait for a new led to arrive…
