thanks for that info, interesting . . .
[quote]
HDS Systems is the only manufacturer to go the final step and calibrate each flashlight. We measure the output of each flashlight after it is completely assembled and adjust the output to produce the specified lumen output. This method allows the LED to warm up to operating temperature as part of the measurement process so the flashlight's true lumen output can be measured and adjusted under representative operating conditions. Thus, our 250 lumen flashlight can be counted on to actually produce 250 lumens.
[/quote]
JasonWW
(JasonWW)
May 22, 2018, 3:26am
442
emarkd:
I see a need in the flashlight world that isn’t currently being fulfilled on an affordable/practical basis. Would be nice if:
(2) a flashlight manufacturer would sell tested lights with a calibration sheet showing that particular light was tested in a sphere. That might cost twice as much (or more) than a normal production run - but would be worth it as a reference.
You said “affordable/practical” then comment that you’d pay double for this service. At the risk of starting to sound like an HDS fanboi lol, I’ll just point out again that they do this with every light they sell, except instead of providing a certificate of that lights output, which would just lead to pissed off customers who didn’t get the brightest samples, they tune down the high performers, tune up the weaker ones, and sell them all with the same exact certified output (but variable and undocumented runtimes). At least, that’s the claim and I have no reason to doubt them. And yes its costs double (or more) than most other similar flashlights, but I find them worth the expense. So while I agree it would be nice to see more makers doing this, you can have what you want right now.
I think he meant something more like starting out with a Convoy S2+ for $15 and then getting it measured and then selling it for $30.
HDS is in a very different price category ($230-$300).
Maybe a tested light under $50?
Newlumen
(Newlumen)
May 21, 2018, 6:13pm
443
maukka:
If the integrating properties aren’t perfect it’s better to calibrate using a light with a reflector, since that’s what the tube will be used for.
The S2+ on a med mode and the BLF348 are very stable so they’ll do fine.
edit: the power supply suggestion is good. TA could just send the head of an S2+ without a driver with leads hanging out from the MCPCB. If he has an accurate PSU we could just drive it at 100mA to take the battery out of the equation.
Hi boss, do you have a list of light that you measured with your integration sphere?
Newlumen
(Newlumen)
May 22, 2018, 1:28pm
444
I am getting my lumen tube today. Yay .
maukka
(maukka)
May 22, 2018, 1:33pm
445
You can check my started threads after 7/2017. All the reviews done after have been made using the sphere.
teacher
(teacher)
May 22, 2018, 3:34pm
446
I got mine last Friday, but have not had time to do anything with it yet.
It looks like rain today though so maybe I’ll have time to check it out further.
Well done TA, the tube looks well made!
Thank you……. :+1:
Out of curiosity, I emailed HDS and asked what equipment they use to calibrate each light. They replied right away.
SKV89
(SKV89)
May 22, 2018, 7:52pm
448
I just received my sphere today too. The box was all wet because the USPS guy just left it at my door without ringing door bell last night. I won’t have time to play with it this week but will do so after and report back.
Newlumen
(Newlumen)
May 22, 2018, 8:05pm
449
I got the lumen tube… is the flashlight bezel suppose to touch this thingy ???
Texas_Ace
(Texas_Ace)
May 22, 2018, 8:32pm
451
Glad you got it!
That is the diffuser, you don’t want to put the light directly on it or it could melt.
The centering rings should be inside a bubble mailer in the box. Simply pick the one that best matches the light you want to measure and lay it on top of the PVC. It should fit inside the lip at the top of the PVC.
Then simply hold the light roughly level with the centering ring, move it in and out until you get the best readings.
It should come pretty naturally once you try a few lights.
Newlumen
(Newlumen)
May 22, 2018, 8:57pm
453
I did the kawi’s way… i put one layer of plastic on the sensor and the number were reading lower…
Turn on… general reading…
Noctigon m43… 7200 lumen
Fenix L16. 1950 lumen
Fenix tk35ue… 3640 lumen
Blf q8. 5230 lumen
Malkoff wildcat v6. 1200 lumen
Lumintop odf30. 3510 lumen
Thrunite tc20. 3280 lumen
I measure tn42vn90… 5000 lumen… it was about 5200 lumen turn on and stepping down gradually…
From my general testing, ths lumen tube is pretty accurate without spending thousands of dollar…
Thrunite catapult v6. Using shockli IMR
Turn on. 2320 lumen
@30 second. 2200 lumen
SKV89
(SKV89)
May 22, 2018, 8:55pm
454
Newlumen:
Blf q8. 5230 lumen
Turn on. 2320 lumen
Glad to see a measurement of the TN42vn90. Did you add an extra layer of diffuser sheet at the meter?
Newlumen
(Newlumen)
May 22, 2018, 9:03pm
455
Yea. I will test more lights especially Tn42vn90.
My Malkoff Wildcat with 3 new batteries…
Texas_Ace
(Texas_Ace)
May 22, 2018, 10:03pm
457
I have no idea what the ratings on most of those lights are supposed to be, would you might posting the rated lumens with the measured lumens?
Also some readings without the plastic would be nice to get a better idea of a general purpose calibration factor for everyone.
Sooner or later a number will have to be averaged out and selected for all of them to get comparable readings.
Newlumen
(Newlumen)
May 22, 2018, 11:25pm
458
So far I get better reading with the plastic… it is pretty consistent…
Newlumen
(Newlumen)
May 22, 2018, 11:39pm
459
How do I make this tube stand level?? I can’t twist it anymore.: do you use heat gun ?
Newlumen
(Newlumen)
May 22, 2018, 11:41pm
460
I want to make my lumen tube stand like the one in the first photo…
