I ordered before from all mentioned Liitokala stores on aliexpress (i look which one is cheaper at that time) and always got genuine and quality batteries.
It’s only “trusted” place that will ship batteries to Croatia for reasonable price.
I am talking about at least 100 cells ordered, different models, for me and friends.
Now I have 12pcs 30Q ordered, and I hope this is also good product as before.
Yes, I don’t think there are valid complaints about fakes from the good stores in the past. I have received genuine cells as well. The issue seems to be that the stores are now showing a picture of a 30Q cell with 4 prongs on the positive terminal, which indicates they are fake.
I guess there are 3 possible explanations:
1. They are fake.
2. The picture is wrong, but the actual cells have 3 prongs and are genuine.
3. Samsung has a production facility that is now making 30Q’s with 4 prongs.
looks fantastic… My problem is the samsung 30 Q doesnt work in my newer zebralights.
I mean, if I tighten the cap HARD, the tail cap makes contact , but it’s a lot different than the one sanyo cell I have.
You can see the samsung is a mm taller or so… I need to start rolling into cells that work in all lights…regardless of length.
It’s a pain have light specific cells
You may have crushed the one a little. For a button-top to fit in a Zebralight, you’d have to screw the tailcap down really tight, which would probably dent the positive button top. But it should still work fine in the Q8, since it doesn’t require much of a button to make good contact with the brass ring in the head.
Make sure to only use flat-top unprotected cells in any of the new 18650 Zebralights. Pretty much any good brand should fit, as there’s a little bit of tolerance over 65.0mm, but not much.
Yes! If you’re in the US Liionwholesale is awesome! When an address mistake caused my package to get lost in Narnia somewhere, they were very easy to contact and work with. Their prices are great but their customer service is top tier.
I ordered 4 x Panasonic NCR18650B end of march for $11.99, free shipping, from https://liitokalahongkong.fr.aliexpress.com/store/217753 and received them last week after almost two month transit time which is quite slow. Whatever i order from china usually gets delivered in two weeks from most vendors including AE various shops.
Cells look genuine and had 3.7-3.8V out of the box. I haven’t tested them further though.
I bough from that store 4 Liitokala 3000mAh that were supposed to be LG HG2.
My lii500 shows that all the cells are around 3300mAh so they can’t be HG2.
I’ve made 2 orders from different stores. Both say on the listing that they are Sanyo GAs, but ones from one order looks like samsung 35E (recessed top, 3 prongs) and from other order looks like LG MJ1 (4 prongs). Both measured the correct capacity and seem to sustain the correct max current, but they for sure are NOT sanyos
Im thinking about trying some out HG2’s or the 25r’s but using them for vaping. Now if these prove to be fake would I have issues with vaping if the max discharge is not sufficient?
