adam7027
(adam7027)
May 29, 2018, 7:01pm
104
clemence:
adam7027:
On a side note, if the sw45k will eventually run out, do you plan to stock some alternate 4500K-ish Nichia emitters with 3535 footprint? (I know, that 319A is at most R8000, but could be useful, if someone seeks a balance between output and color fidelity)
The closest match to 219B D220 sw45k R9080 is E21A D220 sm4550e R9080. But this particular CCT/tint is only available in very small sample quantity (100 pcs at most) or …… approximately a million pcs. Those sextant binning is only made to order.
So, for our needs we will have to live with E21A D220 sm453 R9080 or cherry pick ourselves from the sm455 or sm457 reel. There’s another option: wait for special requests from big companies such as Panasonic, Toshiba, or GM.
FYI, Nichia made special 149AM R9080 (unavailable to normal public) specifically for Panasonic’s stadium lights. HD TV football broadcasting is a big business in Japan.
- Clemence
The sm4070e for 219C (which is listed as out of stock on your site) was from a big company special request like this?
How often can you observe and join to these?
Btw, once I manage to set myself up to do simpler reflow jobs, I will take the opportunity to try as many as possible emitters in different lights (I will pull the trigger on a hot plate soon, hopefully)
clemence
(clemence)
May 30, 2018, 12:15am
105
Good morning everyone, will update the listing soon. Still talking to my coffee here.
- Clemence
Marki
(Marki)
May 30, 2018, 9:54am
106
Payments sent for following order.
Noctigon 3XP Parallel $3
219B-sw40 + 219B-sw45 + 219C-sm573
2× 219B-sw40 + 1× 219B-sw45
3× 219B-sw40
Noctigon XP16 $1.85
1× 219B-sw45
4X LED reflow soldering service $2
LEDs for above will used from pool below, rest will be sent as leds.
12X 219B-sw40 $33.6
6X 219B-sw45 $16.8
1x 219C-sm573 $3.5
International economy service: $5
Total $71.75
Schoki
(Schoki)
May 30, 2018, 1:17pm
108
Forgot to put my BLF username in the Paypal comment.
Paid for:
6x sw40
4x sw45
1x VR16S1 MCPCB
1x E21A SM653 R9080
Total: $39.73
Flat-ray
(Flat-ray)
May 30, 2018, 2:47pm
109
Please, sign me for
2x sw40
2x sw45
Intl shipping $5
Total amount: $16.2
Flat-ray
(Flat-ray)
May 30, 2018, 2:55pm
110
PP sent for the above order
Oooh, I see there are E21A with 6500K and R9080. How am I supposed to retain any money at this rate?
I might have to upgrade shipping too so I can get all these goodies quicker!
Update:
I just did it. Order 10226.
So now I'll be getting 3 of the (10) 2000K E21A mounted to boards, and 4 of the (6) 6500K E21A mounted to a quad board.
I upgraded shipping to express so I'll be needing a $5 refund for my previously paid shipping, I'm sorry about that.
goshdogit
(goshdogit)
May 30, 2018, 5:14pm
112
The Google spreadsheet correctly lists my order of 24x SW45k emitters and two loaded 4XP MCPCBs, but shows:
“2x sw45k soldered on 2x Noctigon 3XP [PO]”
which should read:
“6x sw45k soldered on 2x Noctigon 3XP [PO]”
I’m pretty sure you wouldn’t reflow a single emitter onto each of my two triple boards, but just wanted to make sure.
clemence
(clemence)
May 31, 2018, 1:28am
113
Lyyyyghtey:
Update:
So now I’ll be getting 3 of the (10) 2000K E21A mounted to boards, and 4 of the (6) 6500K E21A mounted to a quad board.
I upgraded shipping to express so I’ll be needing a $5 refund for my previously paid shipping, I’m sorry about that.
Did you mean 3x E21A on a single VR16S1 MCPCB?
I see, you meant 3x E21A 2000K on 3x VR16S1
Yes that’s it, 3x E21A 2000K on 3x VR16S1, one LED per board. Thanks!
steve42
(steve42)
June 1, 2018, 5:03pm
115
Did the 219B 4500 & 4000 go out-of-stock? I was finally going to order 6 of the 4500 & 3 of the 4000 reflowed on 3 noctigon 3XPs.
Hondo
(Hondo)
June 1, 2018, 9:34pm
117
I’ve been thinking (and reading) a lot, and while I thought the 4000k might be just too warm for me, I really should get a mix to try.
So if I may, I’d like to update my 15 emitters from all 4500k to: 9 x 4500k and 6 x 4000k.
Thanks again, and sorry for changing up my order.
Ronin42
(Ronin42)
June 1, 2018, 10:27pm
118
Oops
I checked and you have my order correct but BLF username may not be in pp sorry.
For reference its
8x45
2x40
FBsLights
(FBsLights)
June 2, 2018, 6:12am
120
I would like:
5 x sw40
5 x sw45
Intl shipping $5
Paypal total coming: $33
FB
steve42
(steve42)
June 2, 2018, 11:22pm
121
Clemence, Please ignore my PM. This is my slightly reduced order:
I would like the following 219B LEDs on Noctigon MCPCBs
details of five reflow services in total:
Three Noctigon 3XP parallel only 6A configured with two 219B 4500 and one 219B 4000 each MCPCB.
One Noctigon XP16 single with 219B 4500.
One Noctigon XP20 single with 219B 4500.
My order cost is detailed next. in USD to be sent to your paypal:
eight 219B 4500 LEDs @ $2.80 each = 22.40 USD
three 219B 4000 LEDs @ $2,80 each = 8.40 USD
five MCPCBs:
three Noctigon 3XP @ $3.00 each = 9.00 USD (parallel only).
one Noctigon XP16 1.85 USD.
one Noctigon XP20 2.00 USD.
five LED reflow services three .70 each and two .50 each = 3.10 USD
Postage to USA 5.00 USD
total 51.75 USD
Barkuti
(Barkuti)
June 3, 2018, 5:34am
123
clemence:
All correct
Do these SW40s and SW45s share the same Vf bin/voltage performance group? Hope they're at least quite close for an about even load distribution; if not, in series is the way to go.
Cheers ^:)
