or Oblady oblada for Beatles fans
Hahahaha, you just made my day! :+1:
Oh shucks…I have forgotten and just realized that that song was sang by Sting!
Will listen to it again….
Sting was singer for The Police
I have concluded my Discharge test using my iCharger of a 30q after 14h, 07min. Capacity: 2,860mAh @ .20a — photo in post # 11
from what i see peeking up from the + end those look like the ebl 5000 i got a bunch of.
every one was above 5000 after 2-3 cycles.
but the results with your 30q’s leads me to believe that analyzer is inaccurate.
That’s my long-time observation too….when I started in this hobby almost 6 years ago, I started out with laptop pulls only, no analyzing chargers then, the reason why I got the iCharger (and the Pila IBC and Maha C9000) at that time.
I remember that the only time a cell rating had actually reach or exceed by a bit its mAh rating on the lable from reputable manufacturer is when I set my iCharger to discharge down to 2.50V.
Innacurate cheap analyzing chargers? Welcome to the real world fellows. The current sense resistors used by these devices feature 1% tolerance, let's just start with this, and there are more variables over the table. I believe my Lii-500 measures close to 2% less, based on my observations for various cells.
Cheers :-)
I wrote an honest review about the Zanflare C4 on Gearbest’s website. After that, their customer service team contacted me in order to solve the issues I have with my device. I explained in detail about the high deviations concerning the capacity measurement incl. the fact that charging slot #2 always indicates much more than the other slots.
So…eventually, this is what Gearbest calls “problem solution”. Thank you very much! :person_facepalming:
Dear Thomas,
Thank you for your patiencer.
This charger comes with a volume detection function. Voltage accuracy deviation 2; Current accuracy deviation 5; Time accuracy deviation 1. The capacity is tested by charging voltage, current, and time calculations. Due to the fact that it is not a special compartment, the current market can only achieve a 10 accuracy deviation.
The use of interference Including factors: such as the ambient temperature, humidity, battery type, if the battery installed contacts are good or not and so on. For example, if use different brands of the sub-capacity tester to test, there will be some deviations.
Thank you for your understanding.
Best Regards
Gearbest Customer Service
http://www.gearbest.com/
Received my 5 Dolidada’s looks very nice , firsts two of them is allready in my Lii-500 for test.
Sting…… this is one of my all time favorites by him!!
No battery, charger, or light content whatsoever.
But fond memories………
Excellent choice from Sting’s collection! Enjoying it now….
/\ … :+1:
My results:
Opened dispute!!!
My results:
Opened dispute!!!
Please keep us updated about the dispute. I assume voltage will drop significantly when you use 10 or 15 amps on these cells.
Just sharing the tested capacities on the 5x Dolidada 26650 batteries I bought a few months ago from this AX listing. I thought US$19.xx for 5x 26650 batteries is a very good price at the time.
These were all tested using 0.5A on a Zanflare C4 when I first received these batteries in late May 2018. I was initially quite disappointed with these results, as there were reports these batteries had measured capacities closer to 6000mAh.
Battery #1 & 2
Battery #3 & 4
Battery #5
I repeated the same measurement (0.5A) on my Liitokala Lii-500, which yielded even lower capacities!!
Battery #1
Battery #2
Battery #3
Battery #4
Battery #5
Bad, quite bad Dolidada.
I recently discovered that my Lii-500, on the other hand, is quite accurate with regards to capacity testing:
As things are now, it seems like the available production of PLB 5500mAh cells is not being used by Dolidada, LiitoKala or whatever cheapass rewrapper.
