Cold, yes. Colder than I usually prefer. But at least if it’s like the SST-40 (as is expected), then it should be a pure white, not blue or purple. I put a few dedomed SST-40’s in Convoy L2’s and actually don’t mind the tint for a thrower.
I pulled the trigger on the Aliexpress listing last week. I can’t wait to see how they perform sliced / dedomed - should be good. Not that I really needed 10 of them :person_facepalming: but at less than $1 each, oh well
I’ll try a sliced one in my Amutorch JM70 (now a dedomed XP-L) when I get them. If it improves throw I might test it in my Olight M3XS…
Will definitely update here
I’m sorry but a SST-40 6500K is not pure white. With a reflector you can easily see plenty of blue and purple spill. No doubt it’s a great emitter but I think this ‘white’ tint assumption is way over hyped.
Cool, thank you for reminding me. I just purchased 5 sst20’s from kaidomain. Let’s see if it gets here before the 10 I ordered from aliexpress.
I’m new to this led game. But from the relatively small amount of knowledge I’ve learned all signs are pointing to a the next rockstar LED.
I will test and report back to this thread. Ill do fet with a brand new C8 sofirn and fet with ut02. I’ll start with old pani laptop batterys then work my way up to a Sony vtc4a.
I also have 10 coming from that AE listing. I had been waiting on a response from KD, then just grabbed the AE after not hearing anything for a week or so. Of course KD listed them like the day after I pulled the trigger :person_facepalming:
I will probably order a few. The low Vf and (probable) high luminance dedomed make it a winner. The sofirn C8F triple might be a good match for this LED.
I got my 10 SST-20’s LEDs from aliexpress yesterday, so today i rigged up a DC-DC buck driver powered by 2 sanyo GA,s. Measuring Volts with a cheapo MM. Measured amps with a Uni-t clamp meter. And lumens with a lumen tubes I copied off of VOB’s utube video(that has been surprisingly accurate).
The lead wires are very long, so I’m sure voltage sag is happening.
Here are my numbers. Take it with a grain if salt, or boulders of salt.
