Non Flashlight orders/received
I like it!
Hey Pete, it came one day early! Calibration certificate and all. Zero’s out reliably every time!
What do you mean by this? You turn it on and it is showing something other than zero?
Yes. Then I have to click the zero set. Then I open and close the caliper, it’s no longer zero again!
BTW, this new caliper is perfect! Zero’s every time!
Thanks. Mine does not do that, but even then, I am sure accuracy isnt there. One of these days I’ll get a nicer one.
Got a gallon of WD-40 and a SureShot Sprayer for the WD-40. It works much better than the standard aerosol cans for my needs. I’m using it to coat my drill press exposed steel surfaces and any steel tools that may rust in my garage. It has a much wider spray pattern and finer mist than the aerosol cans. You simply fill the can three-quarters full, and pressurize it with 120 psi and you’re off and running. It works great.
Got some Japanese sealant wax
I’m afraid to ask…
It's just a car wash mitt.
Are the clownfish in there, or on the other side?.
Grit Guard
Thanks to member Venom for letting me know such a thing existed. :slight_smile:
Ordered my 5th Brickwall Filter. I’ve been using these to protect my electronics since the mid-1990’s. Never once had a failure with anything protected by one of these devices. Trust me, it’s light years better than MOV protected surge protectors. Not inexpensive, but it’s cheap if you have expensive equipment that needs to be replaced if there is a major surge from a lightning strike. That said, it will not protect against a direct strike, nothing will.
Check them out
Your Welcome Pete7874.
My DC power supply/tester arrived today.
Nice, klrman! How do you like it so far? Which vendor did you purchase it from?
I really like it. Right away tested some switches and leds and will be really nice for future projects that I have in mind. I got it from Banggood and it came in 11 days. I went on their chat help and asked if they would give me a coupon for this and they did and price dropped to $76.99 so I grabbed it.
Update: Voltage holds steady when in increments of 0.1V but when using 0.10V it swings about 0.15 and then settles between the 0.03 range after a short while.
I went to Home Depot today to buy some Top Soil. But the impulse shopper that I am, I bought this Dewalt bit set on sale… To be honest, I forget what I paid, but it was cheap!
Picked up a 20,000 mAh power bank:
And a cheap beater watch:
Picked up a sleeping mat. Still need to order a tent for the upcoming camping trip.
