The CSM-360 with an aspheric will look like this:
I admit it, actually i wanted to get that feilong when i first got into the hobby!
The one I like most from that manufacturer is the flydragon, with an aspheric and also a regular reflector head, but it is far from a budget light I could assume to buy.
2100, I believe the problem of this huge thing is using a single reflector, surely one small reflector for each die would throw much better, but it would need a huge head..
De-focussing it a little bit to get all emitters on the same area should throw quite well, did anyone try it?
I really like aspherics, but even though it is impressive, I'm not fan of that beam profile.
defocusing would probably help a lot though
anyway, as for this 9xml - i can't figure out why they crammed the emitters together. if it is going to flood you might as well space them out in smaller reflectors like the current 3 and 5xmls.
That would also leave quite a cavern for adding more mass - although a 5 or 6 lb light is a little impractical (for most of my purposes anyway).
Yes Dthrckt, I agree with you 100%, but in the other hand it is good to see companies taking the risk of doing different models even if they are not that good :)
You want more pic - take a look at this forum (english translation link included):
agreed - I don't think it is that bad, actually. I mean, if you have the money to spend on lots of emitters, there's nothing wrong w/ underdriving xmls...
I don't care about the throw figures - if you wanted throw in a light this size you'd go HID, right?
let's hope they're reaching the point where they realize they'll have to begin to use some active cooling if they want to continue to push the envelope.
Yep, fei long in chinese is actually Fly Dragon directly translated. :)
I was hoping someone do some XR-Es in this bugger. Holy !@$!@#@ it'd be awesome. HIDs radiate quite a lot of heat via the front glass though. LEDs do not, it's via the back. LEDs hate heat, HIDs love heat. It is not until about 400W in a 7" portable host that do you need forced air cooling. Yeah, that is like WOW.
some provocative measurements :)
when a couple similar lights popped up on DX I thought it over :) I think it could work really well but it is low on my list of projects (but mostly just because so many other projects already have time and money invested).
Viffer, actually that particular MF 35W is a well known under-performer. :) Measured many times to be in the 50k cd region. Check out tatjamagic's comments in CPF section (and my dialoug with him).
But yes, the 20/24W HIDs are actually even more inefficient. You'd want to go high power with those flashlight host type of HIDs. But don't mix up with those 35W automotive ballasts, those are really different animals....esp after putting them into the big hosts. The Microfire 35W has OP, the SMO ebay/aliexpress 35W gets you slightly over 100k cd actually.
His XTAR S1 figures seem a little low, but anyway that really puts to rest my doubts and i hope the others too!
WOW!
Where do i sign up for it man? :D I mean the flashlight looks cool looking anyway.
Seems to be in the 5000 lumens OTF region.
Throw is a mix. The microfire 35W is measured by many members to be in the 50-55k cd range. Its getting quite high here, and the S1 + SR92 are quite low.
But anyway one thing i can't make sense of is that in the first photo it clearly shows the throw of the 2D80 9 XML to be lower than the SR92. (1) operator error in that first photo maybe?
Still some questions unanswered. Yeah provocative measurements....plus pictures. LOL!
Interesting! And provocative! Just occurred to me that it migth not be a good idea to measure even at 3 metres, which they seem to be doing due to the small spot size.
This would be more indicative of throw. Many metres away.
Haha, so I was just telling about the brand not the model then, How many languages do you actually speak 2100?
I only know spanish and a not that good english :(
I think it was called MS2010 the one with the aspheric lens.
Meh. They probably run each emitter at 1 amp. It seems like a huge waste of money. 3x XM-Ls at 3 amps already produces a good 36 or so watts of power. That is already pretty difficult to heat sink.
Plus, the XM-L curve of wattage to lumen output is pretty linear up thru 3 amps too. So doing 5 XM-Ls at 2 amps isn't really THAT much better than 3 XM-Ls at 3 amps each from an efficiency standpoint.
Putting 9 of them in a light, especially right next to each other seems like a terrible, awful idea.
Don’t xpg put out about the same amount of light as xml up to about 1.5A? Why didn’t anyone ever do anything like this with them? A few less lumens for a lot more throw. Or 9 1a xre. It seems the multi-emitter single-reflector would throw much better than the multiple small reflector setups.
cool monster for the positions of the LEDs I'm wondering if it don't use a Peltier's cell but probably not, wouldn't be efficient
In every multi-LED app that I've seen in a single reflector, throw is compromised.
I have made (or purchased) several in varying sizes, all the way down to twin XPGs in a single P60 reflector ("Linger Special")
Due to packaging, none of the LEDs are optimally positioned in the reflector. This is seen in the relative lack of collimation compared to the S1.
Hi Joe,
It seems that they are driving each at about 1.8A thereabouts, to do 5000L out-the-front (calculated using the excel LED output calculator that you can find here on BLF). That's from my calculated guess on the ceiling bounce on the lux meter.
Also look at the temperature rise, even with the high mass of 1kg for the light/fins, we are doing a delta of 31 deg C or 16 deg C rise to 47 deg C for a run of 10 minutes. XTAR S1 is 18 deg C delta and SR92 is 19 deg C. I have seen the Xtar S1 in detail, no way that it or the SR92 has a lousy thermal path from the MCPCB to 6061 host.
You mentioned 2A vs 3A. For info : 1.8A = 658 lumens @ emitter (cold), and 3A = 937 @ emitter (cold). 5 LEDs x 1.8A = 9A = 3290L emitter and 3 LEDs x 3A = 9A = 2811L emitter. That's a 17% difference. I guess it's not a lot but that's not insignificant as well. Esp if you are pushing the envelope....
I just want it to be cheaper....
