Wavien collars are SOLD OUT [limited production]
I have the Jaxman Z1, just curious that the focal length (around 27mm) is greater than the collars (12.5mm), will this affect the size of projected die or will there be light spill?
The focal length of a lens has nothing to do with the focal length of the collar.
The NA of the lens is what matters since the collar has a 60 degree opening only.
I was going back and forth between those and couldn’t decide.
Thanks!
Ok, but wouldn’t the Z1 lens still be something like 27mm from the led to focus the die and in turn have a gap between lens and collar top where light from collar would widen as it exits the aperture of collar?
Yes it would, that’s why I said that the numerical aperture is what matters.
not sure but this looks like waiven copy, found on aliexpress
Looks like a parabolic reflector to me.
Yeah think your right on that the description was
10pcs 50mm Led Lens Base Housing For 5W 10W 20W High Power Led in Round Shape 45mm Lens
Yeah, sorry parabolic reflectors won’t work, which is what 99.99% of everything on the market is.
only ~5 collars left :open_mouth:
In this german thread is a pic from kenjii
https://www.taschenlampen-forum.de/threads/wavien-kragen-collars-in-zukunft-wieder-erhältlich.63947/#post-912793
Thank you very much.
The 2013 Wavien patent describes a parabolic collar, which they claim works better than a spherical one, particularly with mutiple LED emitters.
“The parabolic reflecting collar is made by rotating the parabolic curve around the axis which goes through the focus and is parallel to the directrix. The resulting reflector is round with a parabolic surface. Light emitted from the LED placed at the focus is reflected from one side of the parabolic surface, becomes a parallel beam, incidence onto the opposite parabolic surface, and refocused back to the LED itself. One major difference between this parabolic recycling collar and the spherical recycling collar as shown in FIG. 1 is that the light emitted from a point at and near the focus will be reflected by the parabolic reflector twice and back to the same point where the light is emitted. With this property, with used with packages with multiple LEDs and multiple colors, each LED will be able to perform recycling of its own light independently and each LED with its own color will be able to improve the brightness independent of the other LEDs and colors.”
Collar arrived, nothing to use it on yet though.
Yes but that uses two parabolic reflectors, one facing forward and one facing down. You can’t replace a collar with a single parabolic reflector that is upside down.
The regular spherical collar reflects an inverted image which is why you can’t use it with multiple different coloured LEDs.
The spherical collar is better however because it only reflects light once instead of 3 times and it also reflects back at exactly the same distance from where it was emitted, which means that the reflected die image has the same sharpness as the original die, with no divergence.
That looks really good, seems like they did go away from the slice method.
The other side looks sliced for sure FWIW
Well from your pic it seems like there is definitely some thickness to the glass around the hole, so maybe they sliced part of it but not all the way.
This is how the old collars were:
With 0 thickness at the edge which resulted in a not-so-clean circle.
I see. It is as you describe and not like the above picture.
Some measurements:
12.56mm inside opening at top (ID)
31.77mm wide at bottom (OD)
3.63mm bottom wall thickness
Thank you to everyone that showed interest in the collars enough to make this possible <3
I also said thanks to my Marinebeam contact on behalf of us at BLF, here’s their reply:
“My pleasure. I appreciate your help with the communication. I have been trying for more than a year to make something happen, and while they were very supportive, they didn’t quite have a direction on this ironed out, and they surely had much more critical irons in the fire. They are really just regular guys, not so unlike us, that have mortgaged good jobs and their futures to buy these patents. I spent a lot of time at Wavien also, and they too were good, hardworking, and exceptionally gifted people trying their best to get this technology out there.
Contrary to popular opinion, we won’t make some small fortune on this deal. I wish these collars were some trinket with massive volumes that we could sell for a dollar a piece and make everyone happy. When I factor in the tooling, yield fallout, scrap, license fee, and royalties, it is modest deal for us at best. I am happy to share some of the spoils with Meadowstar too. If they can be successful, it is best for all of us.
I did this BLF deal mainly to get some out there in the hands of some creative hobbyists. Because we deal in so many different products, it is hard for me to spend the available time 100% on flashlights, so a group of keen tinkerers trying different hosts, drivers, and emitters can cover much more ground than we can and push the envelope, further validating the concept. We are all on the same team trying to make cool long-throw LED flashlights. Should someone figure a clever concept for making low-cost collars, that is good too. Same with any host that gets well-enough developed that it is easy to drop in a collar. We can have the host produced (or re-produced using the basic concept), drop in a collar at Marinebeam, and sell to the public. We could even have a BLF version and pricing for BLF members.
Have a great weekend, and let me know of any interesting successes.”
Can you measure the thickness for us?
