The There Are No Stupid Questions Thread
Thanks CN and enderman…
You could turn it off, disable it, delete the .exe, turn on “metered access”, all the usual tricks, and it’ll STILL come back to bite you when you least want it to.
M$Widows is the Borg of OSes.
This took some digging. Apparently there are three types of ZWB glass. It’s a model number for filters manufactured by Optima, a Japanese optics(?) company.
Source
” BlueSwordM ” You are correct for most peoples needs. My Wife worked at a computer repair shop once and we learned a few things about Windows. So one thing that does help is to only do updates when you are prepared to, several restore points made, back up important info, and a some time in case things get screwed up. You can do updates every 6 months or more. I have not done an update in years with no problems, but then again, I don’t play games on it, just surf the net.
Thank you!
Which tripod mount do you guys recommend for the blf gt and astrolux mf04… thanks.
I just got a new flashlight. I noticed there was some little dust particles on the lens on the inside. So I took the bezel off and cleaned the glass on both sides with a microfiber towel. While I was doing that, dust particles fell into the reflector! How do I get it out of there?? I wish I would have never taken the lens out!
“Canned air”.
Else a little squeezy-bulb thing like to clean camera lenses would work. Just never ever ever touch the reflector.
Don’t touch it with what? Fingers, or the microfiber towel?
Don’t touch it with anything.
Where can I find a replace switch boot for my Eagletac D25A Ti? It’s currently torn and I want to try other channels before going to Eagletac.
Welp. I guess I made my first major newb mistake. I thought a soft microfiber towel would be OK for that but I guess not. It left some fine scratches. Light is still bright so I’m just gonna reassemble it and leave it alone. Lesson learned unfortunately.
What flashlight you have?
SF36.
There are some on KD.
Might not be able to get a white one to fit, think I used one of these on the D25C
http://kaidomain.com/p/S024944.12mm(D
Has anyone else contemplated when technology may evolve to the point that one can have a light permanently embedded in their forehead to allow immediate access to a headlamp by just thinking it on?
Or just buy a whole lotta trits from FT.
Thanks for the tip CRX… was just there and pondering about the height… I’m assuming it would be the shallower 5.5mm…
Is there an alternative for the Courui D01?
https://www.gearbest.com/led-flashlights/pp_85126.html
Why not contacting eagletac?
I needed a replacement lens for my d15lc2 and after contacting them they have sent me a new lens for just the shipping
Costs.
