The router I have now is a netgear R6250 and I agree, the firmware is not the best, I can’t even allocate an IP address to devices, which is super annoying as anytime a device reconnects it gets a new IP (yes, I know I can setup static IP’s per device but I have had issues doing that in bulk in the past, too hard to remember what IP’s are used).
I have been considering flashing DD-WRT to the one I have but when I looked it up it did not look like an official version was released and people reported issues.
Looks like everyone agrees that the AC68 is the one you hunt for. Exactly what I was wanting, a good model to watch for a deal on.
What would be the best runner up model? Anything better that is worth a little extra money?
Wifi performance while important is not nearly as big of a deal for me, I would rather a 5 port router personally as all the important devices are hard wired.
The devices that use wifi generally don’t need a lot of bandwidth (aka, we don’t really steam to mobile devices wireless unless we are fairly close to the router).
The bigger issue are dead spots in the house and dropping the signal ect. these are quite annoying in a few areas.
Sounds like they learned from a mistake in that case. I like ASUS for that, they do seem to improve things if an issue is found. Thus far ASUS has never let me down and has far exceeded my expectations.
All my ASUS motherboards from 10+ years ago are still going strong, many of them ran every single day for that time and overclocked too boot.
I’ve had an AC68R sitting next to an outside wall since Feb 2014. The temp fluctuates a lot where it is (i’m in TX too) and I have not had any trouble. Easily the most reliable router I have ever owned.
They recently renamed the ac68 to just the “RT-AC1900” so you can look out for that one. You can also look into what is involved in “converting” the Tmobile version to a standard 68u, but it’s a bit of a gamble.
The next model up for Asus is the ac87, but I don’t really recommend it because it was a bit of a science experiment with 2.4ghz and 5ghz radios completely separate with different processors and RAM. Asus also announced support would end soon.
Above that you have the AC88 and AC-3100, which are great but a big jump up in price.
Otherwise you can get a Netgear R7000 and install Asus-Merlin through xwrt-vortex. It is very stable and feature-rich, but you don’t get the headline features from Asus like AiMesh, TrendMicro protection, or QOS updates.
In fact, the only annoying thing about my router is that it is sometimes too good. If i’m using google maps on my phone or taking a walk around my neighborhood my device will stay connected until I am all the way down my street. However, the internet is only usable for half or 1/3 of that distance. The phone eventually figures it out and switches to cell or the signal drops but I tend to now set up anything in my garage first then leave. I also use WiFi calling in my house so the router gets some good use.
I bought a refurbished Netgear R7000 from Amazon earlier this year and immediately installed Tomato firmware on it since that is what I’ve been using on my other routers for a long time, so I am just very familiar with it, but the R7000 will take other firmwares such as DD-WRT or Merlin as well.
So far I am very happy with its performance and stability.
This review will give you expected transfer rates using the built-in USB 3.0 port:
You’ll see that it’s faster than AC68U.
However, I personally use a little Intel Nuke PC (running Ubuntu) with an attached portable USB drive for media server duty.
FYI, it runs relatively cool as is, but I have mine sitting on a little 140mm USB fan anyway…
Nope, it was in a nice, cool, finished basement. The problem was it just always ran very hot. Other owners said the exact same thing. Like you couldn’t hold your hand on the top of the thing hot. It seems they wanted it to look sexy and have great range. What it really needed a larger case and more vents. When it reached end-of-life I would need to unplug it to reset it. As time wore on, I also needed to let it cool before restarting it. Eventually even letting it cool before restarting only had a 1 in 10 chance of a successful restart. I would do 10 restarts in a row before it would work. Then it would work a few more days and repeat. That’s when I replaced it.
Their firmware has always been the best I have seen, and with the latest updates they made available the last few months it is far better than it was last year. I have been running the AC88U since August 2016. I was surprised to see such a wonderful set of upgrades for it just a few months ago.
The firmware also just has little things that I think are cool or nice. Like right on the homepage for the router (and in the mobile app) it has a system monitor where you can see what level your processor is running at (separated by core) and how much RAM you are using. There seems to be an arms race for processor power in routers right now, but even the “only” 800mhz dual-core in my ac68 normally settles around 14% processor and 20% RAM with my 15 devices connected.
You can also see what’s connected and what band something is connected to, how much bandwidth an individual device is using, configure parental controls, and shut off internet (but not local) access to a specific device, all from inside the mobile app.
I read your other post where you said your most important devices were wired. That’s great, I wish the fools that built this house had put Ethernet in the walls. In your case the AC68U is what I would recommend.
The “5 port thing”… that’s what I kept my (albeit gigabit) router in place, just with the wifi disabled. You can still utilize the ports on the router. If you’re looking for a gigabit router, obviously an access point isn’t going to address your needs. But it’s definitely something to keep in mind, very useful for getting a good wifi signal.
Regarding range, of course there’s a lot that can affect that. Centrally located is good, but being in a cabinet probably doesn’t help with dead spots and drop outs. That’s why I like my Ubiquiti access point (the LR version is the Long Range one). Running POE, it hides out discretely on my ceiling which I believe helps a lot with range (being out in the open air with fewer obstructions).
I have also use the app to “wake up” my PC using wake on LAN. Wake on LAN is super finicky for any system though so expect to have issues if you really want to do it. It is possible though and I thought it was pretty cool.
Interesting, it does get faster benchmarks in all the tests then the AC68.
Tomato is what I used on my old Linksys routers and I liked it, although some of the creature comforts of a factory firmware are nice.
So what are the pros/cons of the R7000 and AC68? They seem to be the only real options in this bracket of routers.
Running the asus firmware on the R7000, I don’t even know what the missing features do, I will have to see if they are worth loosing.
I do have a mini PC on the network that I leave on most of the time. I suppose I could set it up as a server with USB 3.0 come to think of it instead of using the router. Although I am not sure if it will remain in service long term. Only problem with it is that is also can get restarted / used at random times which is not ideal for a server.
Yeah, the cabinet is not ideal for sure but the alternative option is putting it in a corner of the house basically as the center of the house either does not have a way to get Ethernet cable run or would be “too ugly”. Things improved a lot when I moved it to the cabinet from the corner of the house that it had been in.
Indeed, I plan to use the R6250 I have now as a switch when I get a new router. I am short a few Ethernet ports right now and having a separate switch on the other side of the house makes sense anyways as it will be easier to manage those devices. Right now those devices are running off an old 10/100 switch.
I have never been a big wifi fan, I still much prefer a hard line wire whenever possible.
