20 small as well. :+1:
I would like to add 20 small to my order.
Change please , not 20 but 30 for me , big size .
Thanks
30 Large
30 Small
OK then.
I will keep the spring thickness at 1mm.
I knew something would be wrong if we increased the wire thickness. Thanks for confirming my doubts djozz :+1:
List updated.
We are at 961 big springs, and 407 small springs.
Since there are so many people wanting small springs too, I will now inform the manufacturer to make a batch of smaller spring with these dimensions along with the big springs:
- Spring top diameter: 4,5mm
- Spring bottom diameter: 5mm
- Spring thickness: 0,8mm
- Spring height: 8mm
- Plating: Zinc plating
Doing this allows for lower shipping costs and lower bulk costs per spring.
If anyone wants to change something about these dimensions above, say it to me.
Thanks again for the community. :laughing:
Oh well, I still have a few djozz-springs leftover but I’m curious how these turn out.
10x big, 10x small please.
The manufacturer has said that while it is possible to make 1.2mm wire without a cost increase, making a 1.1 mm is not directly available without a cost increase, so I will keep the thickness to 1mm as initially said, and corrected by djozz, as 1.2mm is too thick and will hurt memory elasticity and may make the spring collapse under a cell.
Is there a limit on them?
Might be in for 20 big and 20 small.
No limit. 1000pcs is just the minimum order. The more spring we can get manufactured though, the lower the price per spring will be.
Bulk purchases really help getting the cost down by a huge factor.
Please add 30 small to my original order post #8
Thanks
List has been updated.
One other thing: would you prefer better spring mechanical properties using Beryllium Copper 38% IACS C17530, or slightly better conductivity using Beryllium Copper 45% IACS C17510?
I would like to know your choices.
20 Large
15 Small
List updated.
1011 big springs and 452 small springs.
45% is the point of the group buy
Is it?
I though it was about providing a better spring than the existing 45% option.
Not only larger bit with better mechanical properties. (Main factor for a spring!)
So that would mean de slightly lower conducting 38%. It has still awesome current capabilities, enough for most of the builds.
When I had the djozz springs made a few years ago by the Tevema factory, the price break for bulk purchase (20 cents! instead of a dollar) was 2000 springs. At the time there was no way there would be interest enough for 2000 springs so I did not dare to go for that number. I’m glad that the interest is so high this time, that helps enormously for the price!
Please please go for the better mechanical properties, the intl-outdoor spring works fine for such a short spring with little travel but a longer spring of the same material will fail bigtime mechanically.
In for 10 big springs
As thijsco19 & djozz said…. the better spring mechanical properties using Beryllium Copper 38% IACS C17530 is surely the way to go.
I was thinking this was already decided?? But either way…. please do go for the better mechanical properties of the 38%.
Thank you for doing this Group Buy also!! :+1: .
@teacher, I was just checking with the community to see if they wanted something else.
This past, I spent a lot of time during my free time during research about which type of beryllium copper that we could use in a spring application.
There are other types of beryllium copper that would be even better suited to a spring. However, they only have 22% IACS, and therefore, not worth the money over a phosphor bronze B-2 spring at 19% IACS.
There is 60% IACS beryllium copper that can be used. However, it is too rigid and its module of elasticity in tension is lower than 38% IACS Beryllium Copper, so not as good for a spring.
TLDR: 38% IACS Beryllium Copper C17530 is best suited for this application.
