The Millie is a framelock. It actually has a SS insert for the ball detent which also functions as an overtravel stop that I thought was a nice touch. Itās an exclusive model only sold by knifeworks.com. When I saw it was down to only $199 I had to jump on it.
Yeah, itās easy to get pens for Parker refills but difficult for those lame old style thin refills
I thought there must be adaptors for that but I couldnāt find one
And on that Fura blade I used a belt grinder on job with a maybe 20cm wheel, I can measure it later
I have no work rest thatās why I couldnāt make a straight hollow grind with a flat ground tip
The finest belt I have is 80 grit but after a good polish itās not rough anymore (even though Iād prefer something like 200 at least)
I guess Iāll stonewash it later, I just must resist to grind it again to reduce some of the mistakes I made
From my I learned job that the trick is to stop when you canāt make it any better instead of continuing to make it worse
Now the blade swings much better than when it was a folding prybar
- adjustable/removable thumb studs (legal carry for example in Germany),
deep carry pocket clip.
Iām not a big fan of the bead blasted finish on the blade so sooner or later Iāll give it a satin or a stone washed finish. I would prefer full G10 handle scales because in my opinion the exposed liners at the end of the handle are only design elements.
Well, I think jig is the wrong term, itās more a holder and a grind stop
I had to do it freehand as thereās no workrest mount on our belt sander
I like that Ganzo with the SOG OEM pattern, too, but I wish they would have left more G10 where the pinky finger grabs it
I get the point to leave the lanyard hole this way, if Iād make scales Iād only leave away the material at the butt though
The clip would have to become as thin as behind the circle, this way itās looking too bulky
I guess Iād prefer an F-753M1 or a small version of the F7621 if they ever make one
Hi Isti - I noticed recently on your blog that someone commented about a Ti/CF Decepticon 2 clone with Damascus blade. You donāt happen to know where he got it from do you? My mate is after one.
