Copper S2+ limited edition
Standard for S2+es. My first 4C I was sure was way warmer than that, ’til I used it tailstanding, and it was quite a beautiful color/tint.
That’s when I noticed that the spill is quite blue and the hotspot quite yellow, due to angular-shift of the tint.
Stick a 20mm TIR in there, and you’ll be really happy.
Thanks for the tip.
I’ve never tried the switch from a reflector to a TIR optic.
Any recommendation for a good source that would fit the S2+ and XPL HI?
Dammit patmurris, before I read your post I didn’t notice the egg :laughing:
Due to a miscommunication I now have both a smooth and an OP reflector, gotta try the OP one and see if it’s better. It is one gorgeous light though.
Subscribed for batch #2, would love an S2+ in copper. And an 18350 tube too, hopefully!
I got assloads of them from Amazon (goggle “20mm collimator lens” there) but you can get smaller quantities from Fasttech, LEDsupply, even Simon’s Convoy store at AX.
I’ve done some “things” with different TIR optics and XPL-HI Led. You may want to see it here: Essays with TIR lenses on Convoy S2+: XML2 + XPL-HI [Update] - #15 by MascaratumB
Go to the 6th lens, A) and B) .
My favourite lenses and the pebbled ones as they “erase” most of the eggs and shifts. They probably work better with domed LEDs, but they perform well on the XPL-HI Leds as well!
I bought mine from AliExpress stores, but as Lightbringer said, there are plenty places to chose them :wink:
Glad Simon is making another batch. I forgot about getting back to this one for too long. Is it just me, or does this thing seem to be screaming for a Triple 219B?
stupid question… I generically ordered these (spot/flood) in XML… Is the best output found with the XPL HI?
HD is better for extracting as much lumenage as possible, while HI is better for throw at the expense of raw output.
is it for sale?
Is what for sale? Or do you mean: does Convoy sell these?
Convoy sells 18350 tubes in: black, grey, red, blue, green, and desert tan for $4.07/pc. NOT in copper.
There’s also the clear version, which is basically with the ano removed with a coating.
I really hope Simon will make up some short S2+ body tubes for the new colors.
The purple looks amazing!
I will concur that those 60deg floody lens replacements on Simon's website (here) work well if you want to smooth out the default beam. I've got the new cyan and orange on order, will wait to see if I want to mod those as well.
Got mine today.
Album with pictures
What would be the best LED (or LEDs) in that light?
If you don’t mind my asking, what was the cost of that copper host?
And how long was delivery time?
3 weeks to middle EU. I got regular version with normal price. Just already assumed that it’ll be a home for high cri emitter :wink:
should I have gone XPL HI… I didnt even think about LED options. I want max blast fyi
Got mine today.
I immediately threw in triple cu pill from kiriba-ru in there and then i immediately decided that it is way too heavy.
Then i went the other route. Stock pill and single Nichia 219C 2700k. It is far from the 3000 lumen output that the triple xpl setup could provide but at least it is more tolerable in terms of weight.
I also decided that the big Kiriba triple pill would be too heavy, so mine got a quad E21a 4000k R9080 setup with LD-A4 driver at 6 amps. Also added a two-channel lighted tailcap, warm-white/orange, to finish the look. Had a pretty bad donut hole so I wound up with DC Fix on the glass, its a bit floodier than I’d like and I’ll probably look for an optic or something instead, but overall I’m really happy with the build.
