Deal is alive now!
Please wait for our pm...
Deal is alive now!
Interested after all!
interested
I just finished running some errands. I will send out in 2-3hrs time. Our AT40 group buy price is $27.99!!
However, there are some things that you guys need to know about AT40 before you make your purchase:
I’m actually looking for a 3A light and not more, for using an Optisolis quad in it, so the limited power is an advantage for me.
With the lens as a flooding optic, scratching it will not be harmfull to the beam, it may even improve it over time.
It looks like the bezel can be sealed with 1 or 2 o-rings, a bit weird that it is not designed like that.
Isnt 3A too much for the Optisolis which Clemence said should be limited to 0.5A each emitter so we should be looking at 2A. I also wonder if the screw locations will fit the 21mm optisolis board. Freeme do you know the diameter of the pcb?
750mA per led is steep but my test shows that they can handle it, at least for a short while
I’m not going to use an Optisolis board but a 20mm XM-board, like I did with my S2+ with Optisolis.
Nichia vs XP-G3
If the response is good for AT40, i will get them to prep for AL1.
freeme, how much moddable is the light? Is there room to use a Carclo optic + lens above the MCPCB?
Also, is the driver: a) 20mm diameter and b) glued ?
BTW, what do you mean by “B finishing grade”?
Thank you in advance
Some measurements for references. Carclo Quad Optic is 24mm x 7.5mm from Hank's site.
My unit did come with minor dings. Some people may feel that this is "unacceptable" for modern manufacturing.
Thanks for the info. It may actually work with the 20mm 4x noctigon boards or the 21mm optisolis boards from clemence. Probably need a washer under the screw, but there will be a annular gap so might not be pretty.
Tried to order from link provided in PM, but Banggood says: “Under Restocking”. Why?
Interested
Yep… I was gonna order the 4 Nichia version but a pop-up said “No Stock”.
So I guess the answer is… none are in stock at the moment.
I asked to be put on the list in Post #138 - did not get a pm
Would like to buy one unit.
Thanks for your answer and photos freeme I guess this would be nice for a mod.
About those “dings” :person_facepalming: …I guess Amutorch is failing a bit in finishing lately Too bad because they have excellent anodizing and finishing in other lights. Is it possible that you got a sample and not a “final” model?
We gotta tell Shirkey about this so that they improve these aspects…
Thanks again!!
Cannot fit protected cell.
question-is possible to use protected? is it not too low output for 4 nichias? 1200 lumens?looks very nice this torch…
Thanks Freeme! Gave me a “preorder” option, good enough. I’ve paid more for less, this looks like a winner for the price!
Like the look and idea behind the cast aluminum head.
