Copper S2+ limited edition
598 posts / 0 new
justanotherguy
Last seen: 6 hours 10 min ago
should I have gone XPL HI.. I didnt even think about LED options. I want max blast fyi
BobbyMK
BobbyMK's picture
Last seen: 21 hours 11 min ago
Got mine today.
I immediately threw in triple cu pill from kiriba-ru in there and then i immediately decided that it is way too heavy.
Then i went the other route. Stock pill and single Nichia 219C 2700k. It is far from the 3000 lumen output that the triple xpl setup could provide but at least it is more tolerable in terms of weight.
 Olight i3s, Olight S1, Olight S Mini, JetBeam Jet-1, BLF 348, Astrolux S41S, UF SK-98, Convoy S2+ 3*XP-G2, Convoy S2+ 3*XPL, Convoy S2+ 219CT, Convoy M1, Convoy C8, Brinyte B158, Courui D01, Convoy L6, Noctigon M43
emarkd
emarkd's picture
Last seen: 1 year 1 month ago
I also decided that the big Kiriba triple pill would be too heavy, so mine got a quad E21a 4000k R9080 setup with LD-A4 driver at 6 amps. Also added a two-channel lighted tailcap, warm-white/orange, to finish the look. Had a pretty bad donut hole so I wound up with DC Fix on the glass, its a bit floodier than I’d like and I’ll probably look for an optic or something instead, but overall I’m really happy with the build.
maukka
maukka's picture
Last seen: 10 months 1 week ago
Now that is tasty and fits the theme perfectly.
BobbyMK
BobbyMK's picture
Awesome job Mark.
How is the output on these leds compared to lets say 219C triple setup at same current?
SKV89
Last seen: 3 hours 50 min ago
emarkd, thanks for posting those great pics! I’m planning to do an E21A quad for the S2+ also but wasn’t sure what optics would work but I’m surprised the stock reflector fits the quad emitters. Please post if you find better optics/reflector without the donut hole.
Btw, that lighted tail switch really goes well with the copper!
kiriba-ru
kiriba-ru's picture
Last seen: 2 days 4 hours ago
I think I need to say that weight difference between stock single led brass pill and my triple copper pill is 22-23gr.
emarkd
emarkd's picture
Thanks for the kind words all, I’m enjoying this build. At the same current the output seems comparable, but the E21a + DC Fix setup is much floodier so its kinda hard to judge. A triple behind either a 10507 or 10511 has much more candela for sure. Its also worth noting that 219b or c is capable of handling more current, so you can get a lot more output from those builds if you push them harder.
As for optics, I’ve already placed an order with Convoy for some of the single optics he stocks, just to experiment. I needed some other things anyway, so I’ll follow up in a couple of weeks when those arrive.
LSX
LSX's picture
Last seen: 1 month 1 week ago
Are more of these going to be released?
mortuus
mortuus's picture
Last seen: 35 min 23 sec ago
i think so but its gonna be a while until next batch..
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
LSX
LSX's picture
Thanks! Hopefully I don’t miss the next one.
djozz
djozz's picture
Last seen: 1 hour 54 min ago
Personally, if I could choose a Convoy light in copper and get heavy anyway, it would not be the rather boring looking S2+ but it would be the S8 Cool
Simon?…
BobbyMK
BobbyMK's picture
We need to make sure that Simon makes some 18350 tubes for it.
I messaged him a while back, even before i got mine and asked if hes planning to do some short tubes. His answer was no.
But i think with some persuasion from this community we can convince Simon to make some, i think most of us would want one.
shirnask
shirnask's picture
Last seen: 3 hours 34 min ago
YES!
CrashOne
Last seen: 36 min 41 sec ago
In the FB group Flashlight Fanatics someone has 3 copper hosts for sale:
https://www.facebook.com/groups/396898630419281/permalink/1653264814782650/?xts0=68.ARB6d6JqFhzFdEsXqnSy5j6MT6t4PjdeXEd0rnAkWBmT5qEeb0augYu0H7EkCet-1FXcyonQFsBJMhh_VQ7fChEX72oH1icEQKQJwZ9F0meSPMDcDArOJMUN2wZXOzVzK39KUFU&__tn__=-R
He says they are original, which I think is a bit strange…
chakrawal
Last seen: 11 months 4 days ago
I think you miss understood. They are Convoy S2+ CU not just hosts lol.
CrashOne
Even if it’s the complete light, I think there are BLF members that still want it Smile
I would buy the light and use it as a host Wink
Threadneedle
Threadneedle's picture
Last seen: 2 weeks 2 days ago
justanotherguy
I’ve got two myself. EDC at work.
Sold the sinner (apples to orange I know)
Diodek.pl
Diodek.pl's picture
Last seen: 10 months 4 weeks ago
Copper Convoy available again
https://www.aliexpress.com/store/product/copper-convoy-S2-pls-note-LED-and-driver-in-the-comment/330416_32884358055.html?spm=2114.12010608.0.0.7cf073941xp83J
www.diodek.pl Convoy, Astrolux etc. flashlights test and more. My YouTube channel.
justanotherguy
Thanks for the heads up..
Which led do I pick for maximum brightness…?
I have these in XML..would XPL be brighter or punchier?
Diodek.pl
Diodek.pl's picture
XPL is a bit stronger. One of the orientation tests.
Threadneedle
Was there any reason for the knurling to change from diamond to square? The knurling on the head has changed to 6 fins also.
KawiBoy1428
KawiBoy1428's picture
Last seen: 8 hours 26 min ago
From personal experience, the Traditional Crush (pressure) knurling is very tough to do on very soft alloy’s like real copper, the soft material starts to build up on the roller blades. Turning and side broaching to produce the square knurling is a tad bit easier…
KB1428 “Live Life WOT
DB Custom
DB Custom's picture
Last seen: 3 weeks 2 days ago
That graph comparing the XM-L2 to the XP-L is misleading, it uses an old outdated XM-L2 against the highest binned XP-L. If a newer high binned XM-L2 U4 were shown against it the graph wouldn’t show like it does. Just saying.
emarkd
emarkd's picture
I don’t know anything about machining so I can’t speak to the reasoning, but I really like the new look. That “grenade grip” is very popular for good reason, and I really dig the cooling fins on the head. Gotta have a new one too I guess… Smile
Diodek.pl
Diodek.pl's picture
Of course, you are right. That’s why I wrote to treat it roughly. The author of the question does not give specific diodes. In fact, the author of the question referred to XML and XPL which have successors. Maybe it’s better to ignore this chart.
Barkuti
Barkuti's picture
Last seen: 12 hours 41 min ago
KawiBoy1428 wrote:
From personal experience, the Traditional Crush (pressure) knurling is very tough to do on very soft alloy's like real copper, the soft material starts to build up on the roller blades. …
I have a limited experience crafting with copper, and I can say it definitively started to build up around my cutting bits when chopping a 1mm copper sheet carefully under my vise attached Dremel style multitool. This for sure has to do with its malleability/plasticity with its super high thermal conductivity. I ended up managing fine results, but took careful filing:
Originally posted on Wed, 09/12/2018 - 02:41. Edited for orthography fix.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Viruses DON'T cause diseases, they rather are a consequence of them. Read the book “Béchamp or Pasteur” by Ethel Hume for more information.
Aviationtech
Aviationtech's picture
Last seen: 2 months 2 days ago
I missed the first batch, went ahead and purchased one of these from the second batch, XM-L2 T4-7A
DB Custom
DB Custom's picture
Nice work Barkuti, looks very well done. Wink
