I can at least confirm that the D4S is throwier than the D4, and it has a nice beam with only minimal artifacts. It has a round hotspot, a reflector-like spill area, and then some mild extra junk outside the edge of the spill.
It also has cyan-colored aux LEDs under the optic, 16 of them, which work like tritium vials.
It’s a D4, but sized for a 26650 cell, throwier, and with some other misc improvements.
Edit: Oh, um, my prototype uses XP-L HI 3A. I’m not sure how the beam looks with other emitters.
just ordered a Shockli 26650 fm Mtn Electronics for my Rofis MR70, almost ordered two anticipating the D4s.
Butt the D4 was picky about its battery fit, so I’ll wait a bit.
I have Shockli’s, black wrapped and blue wrapped LiitoKala’s and the black wrapped LiitoKala’s seem to perform best if absolutes matter.
The Black LiitoKala’s best Efests of dark and light purple, red too. As well as Gold King Kongs and orange MNKE’s and green Moli’s, KeepPower 5200’s and Basen’s…. I, uh, have a lot of cells. The discontinued orange Powerizer LiNiMnCo’s were probably the best, a short cell with high delivery. Been out of population for a while now.
I actually don’t know for sure if those will fit. I only have one 26650 cell and it didn’t fit in my prototype. But Hank tells me the battery tube has been changed to fit bigger cells. And not only is the Shockli the highest-capacity cell in RMM’s store, it’s also one of the smaller 26650 cells. So I think it’ll probably be okay.
Meanwhile, I’ve been testing with a 18650 wrapped in packing foam.
Soooo… A M44? Probably the only thing holding me back from the M43 is the firmware (and it’s not easily changed?). An M44 with D4 firmware, and with a new flash friendly driver, I wouldn’t hesitate buying another light I have no use for, lol.
I wonder if the same $40 price point will stick for the D4s?
Next up, the D1s! Well, not the D1s, but the D1s. Then the D1ss?
Probably FET + Battery. I shorted a D1S driver once on accident by shorting the LED leads, and the FET burned through (very smelly, would not recommend).
Is there a possibility that Hank considers producing a 21700 tube?
I’ve been EDCing my D4 219C lately and the only thing that bothers me is the heat at max level, with LH351D and larger body it should perform pretty amazing. We should persuade Hank to make it into an emitter option.
I’ll have to thank Hank for sending a black-colored light for photography purposes. Those are always the easiest to get good pictures of.
Also, it’s cool white. So I’ll want to swap the emitters. And it has no O-rings, so I’ll probably transfer the rings from the dev prototype. And no label on the tailcap.
So it’s not quite a production unit, but it’s pretty close.
