Dose Gearbest have powerbank better than the TOMO M4
8 posts / 0 new
gamezawy
gamezawy's picture
Last seen: 5 days 22 hours ago
Hello every one
I want to buy a good 4× 18650 power bank that able to give 2A to my phone
I have read the talented HKJ’s Review about this TOMO M4
but i felt he wasn’t very happy about it, and i am making an order from Gearbest that is why i am asking is there is a power bank better than the TOMO M4 at GearBest ?
gamezawy
gamezawy's picture
question in other way should i buy the TOMO M4 ?
Aleister
Aleister's picture
Last seen: 1 month 1 week ago
I don’t know about TOMO, never had one, so I’ll just share my experience with the 4*18650 powerbanks that I have used.
Soshine E3S: It melted on the first weekend I over-used it (charge->discharge non stop). And started smelling… And stopped working…
Epilot E4: Has survived without a hiccup for two weekends until now, same use, charge -> discharge -> repeat for the most part of each day.
I would buy Epilot again, but not Soshine.
Let a flooder be my wife and a thrower be my mistress
kuoh
Last seen: 1 week 5 days ago
I have a couple of M4’s and have been happy with them. The LCD display provides a lot more info than most other power banks with just 3 or 4 LEDs. I can leave 4 cells in it for a few months and is still usable. The M3 on the other hand, drained the cells down to 0V. I don’t know if I just got a bad one or if they changed circuitry between the models.
KuoH
KuoH
d_t_a
Last seen: 23 hours 2 min ago
Got curious by the different TOMO models, so I checked their descriptions:
TOMO M4 = micro-USB input (seems to be previously known as TOMO V8-4)
TOMO T4 = micro-USB + lightning input
TOMO S4 = micro-USB + lightning + USB-C inputs the above inputs are limited to 5v/1A, no matter then type of input
TOMO Epilot E4 = micro-USB input (up to 5v/2A); LCD now has additional temperature display (compared to the above 3 models)
It would look like the Epilot E4 is the latest and most advanced of the above; even though it doesn’t have the extra lightning and USB-C inputs.
I wonder which DIY powerbank has UPS feature (ie. supports pass-thru charging; can charge the powerbank, while at the same time the powerbank is charging another item, without having USB power cut-off)
ggf31416
Last seen: 4 days 4 hours ago
I don’t think DIY powerbanks are worthwhile as they are now if you already have a 18650 charger. You can buy a good powerbank with integrated batteries for only a few dollars more. Sure, the concept of an enclosed charger that can be used as power bank, saving the weight of a separate one and allowing independent renewal of electronics and batteries, is quite good, but IMHO the current offerings lack enough quality/$.
gamezawy
gamezawy's picture
I think the TOMO Epilot E4 is a good option
angerdan
angerdan's picture
Last seen: 6 hours 36 min ago
