Well…actually, you can carry more than one or two weapons at a time. One’s just need to use some scotch tape. :sunglasses: Every once in a while I love to see Ripley kickin’ those Alien asses… :smiling_imp:
I’m not even sure the IMAX style hobby charger will get you much further ahead, unless you are lucky. I have an Opus, several Lii-500, and 2x Zanflare C4, along with an Acucell-6 and Turnigy MAX80W both of which are in the same ‘family’ as the IMAX B6.
I just finished a test of small camera Li-on tests. I get results with a spread of ~ 20% between the 2 hobby chargers. Which one is right? It may be a problem of working with small capacity batteries, tiny wires (high IR), shaky connections, and only able to throttle the discharge down to 100mA. But, at least I’m comparing various cells to one another using the same equipment.
On regular 18650 the hobby chargers are reasonably close to the 4-bay chargers. I seldom use those anymore.
The other 3 4-bay chargers are close enough I don’t worry about the results much. I use what is convenient unless I have a special test to do. The Opus has more options and power, the Zanflare does IR better than the Opus, or is at least more consistent. The IR on the Lii-500 is useless. I’ve have 3, all acted the same, so it seems to be a problem with them in general. The other functions are good.
These are all consumer grade ‘hobby’ chargers. I’d say unless your unit is notably out of whack, you get what you pay for.
I recently got a Zanflare C4 on sale for 17.99 shipped. I don’t have 5 other chargers to compare it to, so for me it is perfect. Perhaps it reads high in capacity, but it will certainly show when the capacity is reduced, and when the IR increases. A man with one watch knows what time it is, while a man with two watches is never sure . . .
As the previous poster said, you likely get what you pay for.
as a new owner of a Zanflare C4, I've been busy cycling LSD cells that for the most part have been sitting unused for the last year or so, or employed in low-discharge devices.
HJK mentioned that the C4 would discharge his Eneloops down to 1.05 V, however, I'm seeing cells below the 1 V mark, currently staring at two cells reading 0.92 V, and one has gone down to 0.87 V.
Will the C4 keep discharging as long as the battery is capable of providing the required current of 0.5 A, regardless of the voltage?
Is this voltage realistic or an artifact?
Assuming the data is not garbage, I'm guessing a low discharge voltage does not bode well for the battery's real world usability?
I’ve tried out the ZanFlare C4 charger’s NOR Test and noticed the following:
the lowest displayed voltage (discharge portion) when using NiMh appears to be 0.87v (exactly the same as what you noticed) - it stops discharging when it hits 0.87v (what I’m not sure is that the 0.87v is probably the voltage under load? or could it be unloaded voltage?)
the lowest displayed voltage (discharge) when using Li-Ion appears to be 2.76v (after the display touches 2.76v, it will stop discharging)
HJK mentioned that the discharge curve is constant, so the voltage displayed should be under load.
Since voltage drops more under load in a cell that has higher internal resistance, I wonder if the explanation is simply that HJK's Eneloop have lower internal resistance than the cells I'm using. His NiMH IR test table shows about 100 milli Ohms, lower than most my NiMH cells, so there's that.
The charger employs fixed discharge cut-off thresholds to avoid damaging cells, maybe HJK's Eneloops could no longer provide the required current before hitting that voltage, I'm not sure.
2.75V is a common cut-off voltage for discharging LiIon, your result seems consistent with HJK's charts.
FWIW, I conducted capacity testing on four Panasonic-Sanyo NCR18650GA batteries today using my Zanflare C4 and happened to catch one (a straggler) hitting the same 2.76 v minimum value. One second the value was 2.76v and then the next it was 2.8 v and rising. Missed the other three because they were in the lead.
I received four new NCR18650GA batteries from Orbtonics and tested their 1 kHz internal resistance (IR) with my RM8124A, and capacity with my Zanflare C4 analyzing charger. The IR reading were well-grouped and met the Sanyo NCR18650GA specification of < 38 mΩ. But the C4 capacity readings were too high compared to the typical capacity listed in the NCR18650GA datasheet of 3450 mAh. This caused some misgivings about the C4 and led to additional testing, as shown in the tabulated data below:
Evaluation of New Panasonic-Sanyo NCR18650GA Batteries with
Zanflare C4, MiBoxer C2-4000, and LiitoKala Lii-500 Analysing Chargers
Sep 7 - 11, 2018
Battery
Number
Capacity1(mAh)
1 kHz Internal Resistance (mO)
Zanflare C42
Trial 1
MiBoxer
C2-40003
Zanflare C4
Trial 2
LiitoKala
Lii-5004
1
3627
3317
3744
3361
19.4
2
3708
3300
3768
3392
18.8
3
3737
3322
3812
3382
18.9
4
3674
3300
3702
3325
18.8
1. All three chargers were configured with a 0.5A discharge rate.
2. The minimum Zanflare C4 discharge voltage was about 2.76 V.
3. The minimum MiBoxer C2-4000 discharged voltage was about 2.80 V.
4. The minimum LitoKala Lii-500 discharged voltage was not observed.
So, I decided to re-test the batteries with my MiBoxer C2-4000 - which provided results somewhat low when compared to minimum capacity listed in the datasheet of 3350 mAh, but seemed more reasonable than the Zanflare C4 results.
The Zanfare C4 got a second trial at evaluating the batteries, but the results were even higher than the first trial.
The final test was with my LiitoKala Lii-500 which provided the most reasonable results. Most of the Lii-500 measurements fell between the minimum capacity of 3350 mAh and typical capacity of 3450 mAh. It also closely resembles the data in the chart below from this HJK post.
CONCLUSIONS:
I no longer consider my Zanflare C4 a reliable analysing charger [for measuring the capacity of 18650 batteries - Edited].
Until I can find something better, my LiitoKala Lii-500 will be my go-to analyzing charger.
My SM8124A Internal Resistance meter still performs reliably.
After conducting these tests, I am confidant that my new NCR18650GA batteries will work well.
Wonder how much variation there is in individual units, components over time, and just plain assembly?
I’ve had 3xLii-500 and 2xC4. They are very similar units. I consider my C4 to be more accurate than the Lii-500 using an Opus and 2 different hobby chargers to help compare results. All of mine are more than 2 years old. Maybe that makes a difference…?
The IR of the Lii-500 is completely useless on all units. The C4 IR seems more reliable than my Opus, but they are kinda close. Neither of those is very accurate but they seem to get in the ‘ball park’ and determine good from OK from poor.
What is interesting is that I've had very good luck measuring capacity of Ni-MH batteries with my Zanflare C4 very recently, as illustrated in this post.
Just charged 4 30Qs new from LiionWholesale on my Zanflare C4 . Although I bought it long ago, it was my first use. IR was showing each cell in the hundreds of M ohms, even after charging the cells and cleaning the contacts. Same batteries in a Jionrun charger measure 40 M ohms. These IR measurements are all over the place . Don’t see much usefulness in them .
Which makes me further think there may be some significant variation in components. My particular C4 has the most consistent IR measurements of all the chargers I have that will do it. It’s one of the major reasons it’s one of my favorites.
I’ve seen a fair number of electronic products brought down by ‘success’. They work hard to get a decent unit to market > the market likes it because it works well and is a great deal > word spreads, purchases flood in > small company can’t keep up with the demand > they desperately start shopping for alternative component sources (often inferior but cheaper, or at least available) and slapping new units together as fast as they can to keep up, but they simply cannot > quality falls, failures accumulate > the market sours on them with the new rapid distribution of information.
On to the next ‘victim’. It’s a whole new world. It’s no longer dog eat dog, so much as rabid bear vs. enraged wolverine.
Anyone know if the C4 has been discontinued? I noticed the link to it on Amazon comes up with a page not found error and Zanflare’s merchant page no longer has any link at all to it, though it still shows a picture of the C4 on that merchant page.
Zanflare’s website still shows the product, with no mention of discontinued, but they have the same dead link to Amazon, page not found error.
Seems like Amazon would have been a primary US sales point for this so it is curious that the whole page was pulled. They still have the C2 (USB charger) and Sh54 solar charger.
The C4 also shows “Discontinue” (can’t add to cart) on Gearbest.
I sent Zanflare an email asking what’s up, will report back if they reply.
Edit: Heard back from Zanflare:
… and yet, those two don’t have stock, nor does Banggood or anywhere else I looked.
It’s back in stock on Amazon now, also discounted like it was 5 months ago, with a -$12 coupon code 3H3FEL8G discount bringing it down to $18, but I don’t know when this discount will end. Since it has been out of stock for a while it might sell out faster than usual.
