My nephew just asked me to grab another BW-MF8 cable for a friend of him. They seem discontinued, and now they're selling a downgraded and more expensive BW-MF10 version. You just lost another customer here Banggood Bangbad.
Cheers :-)
Originally posted on Tue, 07/17/2018 - 13:43. Edited to add joke.
I like your spreadsheet
There seems to be a few typo’s for the Anker cables. Their site, for some weird reason, only lists AWG for the basic PowerLine
30cm - 24AWG
90cm - 20 AWG
120cm - 20 AWG
I think that question can’t be answered without knowing the AWG of the power wire.
The construction can be super strong but if the wires are thin then the losses will be bad.
Simply having large gauge doesn’t make a cable good.
The flexibility and durability of the insulation, the quality of shielding, the reinforcing cables inside, the joining between cable and connector, and many other things also matter.
Having had a Dash Charge cable which uses 18AWG wires, and is a great quality cable, and the fact that UGreen cables are great in general, I would have no problem that it is a high quality cable.
Thanks! The more advanced meters now do this automatically. You plug them in directly to the supply, then with the cable in between just like you say, and it calculates the difference. Only thing is most meters only have male USB A in or micro USB, so you can only test micro USB cables. Unless you have this:
Converts micro USB, USB C, Apple Lightning and even direct + and - into female USB which you can then plug your meter into.
I had already bought the Qoopow Qualmeter before I found that though. Yes it’s overpriced, and doesn’t give you direct results.
I bought that interface converter board too, but haven’t used much. It’s handy for converting various interfaces. But for measuring resistances, then I won’t exactly recommend as the board will also add some amount of resistance (so it will affect cable resistance measurements by adding some amount of resistance).
It is possible to directly connect the converter board to any given meter by soldering the power leads with short thick wires, plus the data leads. Frankensteining but useful job, of course.
