Simply having large gauge doesn’t make a cable good.
The flexibility and durability of the insulation, the quality of shielding, the reinforcing cables inside, the joining between cable and connector, and many other things also matter.
Having had a Dash Charge cable which uses 18AWG wires, and is a great quality cable, and the fact that UGreen cables are great in general, I would have no problem that it is a high quality cable.
Thanks! The more advanced meters now do this automatically. You plug them in directly to the supply, then with the cable in between just like you say, and it calculates the difference. Only thing is most meters only have male USB A in or micro USB, so you can only test micro USB cables. Unless you have this:
Converts micro USB, USB C, Apple Lightning and even direct + and - into female USB which you can then plug your meter into.
I had already bought the Qoopow Qualmeter before I found that though. Yes it’s overpriced, and doesn’t give you direct results.
I bought that interface converter board too, but haven’t used much. It’s handy for converting various interfaces. But for measuring resistances, then I won’t exactly recommend as the board will also add some amount of resistance (so it will affect cable resistance measurements by adding some amount of resistance).
It is possible to directly connect the converter board to any given meter by soldering the power leads with short thick wires, plus the data leads. Frankensteining but useful job, of course.
It could be because I’m using a battery as a load and it’s unstable, but shouldn’t the current drop if you add resistance in series with a fixed voltage source?
I mean if you look at HKJ’s reviews like Review of USB battery box Chuwi Q-Power USB-C power bank 10000mAh M10 a lot of them mention
“What happens if the charger drops in voltage or a long cable is used? My usual 0.5ohm resistor shows it clearly: The charger will reduce charge current to a much lower value. ”
With a lower input voltage, you get a lower overall energy transfer. That means to get the same power into the powerbank, it is going to have to pull more current.
However, it is dangerous to do that with a USB power supply, so instead, it throttles back the current so the voltage goes up and the charging can continue normally.
(I didn’t do very “scientifically-controlled” tests though, for some of these tests, the phone is On and might be occasionally in use, but for a few, I might have turned the phone Off or at least in Airplane Mode and tried not to use the phone as much as possible while I’m doing the monitoring. Reason being if the S5 is getting used, the charge current will go up. Also, based on my previous tests of it, when the screen is OFF, the charging current can be a max 1.74A while if the screen is ON, the max charging current is 1.15-1.16A, using a USB meter to monitor; also when the phones charge level is already around 75% or 80% full, the max charging current will also start to get lower and won’t be the 1.74A max charging current when the phone is less than 75% battery capacity, based on the phone’s battery display)
in the above case, as the powerbank’s energy level drops (voltage drops), the S5 will request a lower charging current, causing the powerbank voltage to go back up, and the process repeats itself. (it seems the S5 drops in 0.1A every time it attempts to re-negotiate the charging current)
(this powerbank was from some relative, has little power left, but I just had to test it out… when it was fully charged, it only supplied 894mAh USB-measured capacity to the smartphone)
similar pattern here although it occurs it’s more stable while the energy level is still high, then charging current starts to drop in steps.
(the LG HG2 here in this powerbank is not a “genuine one” but possibly a rewrapped LG HE2 or HE4 since its tested capacity on an analyzing charger is around 2500mAh only — this fully charged “HG2 ~ 2500mAh” was able to supply around 1200+mAh USB charged capacity to the smartphone)
in this 3rd example, a “5200mAh” powerbank was able to completely charge the S5 (the powerbank still had some capacity left)
I think I might have slightly been using the phone during the later parts of the tests, so the CC/CV charge curve at the end has “spikes” (the spike are when the phone is being used, the USB chargng current draw goes up)
