WTS: Calibration lights for DIY integrating spheres / lumen tubes - 67 € -
Well if that one is right then I still blew it!!! That’s the trouble with us foreign guys djozz. You can’t even count on us to get your name right! Sorry if I butchered it…….
After I already had the video done my wife suggested this could be the correct sounding one.
I am also interested in the set :slight_smile:
I have one calibrated light already, but I can’t pass on getting a couple more at this price.
Please put me down for a set when available maukka.
Thanks so much!
Hello maukka,
I've sat on the fence long enough, the splinters are killing me ;)
I would like 1 set of the calibration lights please. I'm not sure just what info you need from me when, so if you would be so kind as to PM me I'll put things into the proper sequence.
And, thank you so very much for your time, effort, generosity, and floating the cost of these lights so that we can have in our hands TWO true calibration devices. This is so amazing!! :)
-Ben
It’s easy. I will PM you for payment and other details (address, email) when the set is measured and ready to go out the door.
maukka, please put me down for a set!
Thank you for the details :) I'll wait for your PM, then.
Take care!
-Ben
I’m jumping off the list for now. When I get back from my vacation I prefer to send you some of my own for calibration, just gotta hope you still offer that service when I’m back. I do not want anything on order from anywhere to anywhere while I’m away, piece of mind is worth a lot. Remove me from the list.
Sure thing. I have enough lights coming in for about 50 sets total so you’ll probably be fine.
1. BLF348
2. Olight i3E
1. BLF348
2. Olight i3E
Maukka’s data:
Wow, I am quite impressed. :blush:
Yea me too. TA lumen tube works really great.
Thanks for sharing steel!
Thanks for the results. So neutral high CRI is spot on, cool white lower CRI is about 3% too high.
I see you have two extra diffusers there. How many did you use on the TA tube?
Here we go with the math again.(Steel’s lights)I took Maukkas readings at 30 sec.
So we got 35 and 34.1 which is somewhere around .972. (so if 40 is the reading-38.88)
And we got 98 and 94.5 which is somewhere around .965. (so if the reading is 485-468.02)
Now, since we have a difference should we average the .972 and .965? ( .968.5 )
We get up into the higher numbers with the S2 and the number goes smaller ,say .945 do we just average all numbers or just the two calibrated lights we have?
Sorry to be so dumb about this. Math is not my forte’.
Since the lux meter is probably not filtered perfectly I would use different correction factors for different types of lights. Check out djozz’s great lux meter tests for more info. Test1, test2, test3, test4, test5.
The difference is mostly due to the tint of LED I am guessing.
These cheap meters are effected by the tint of the LED. Meters that are not biased would cost as much as the whole sphere.
There is not much that can be done to correct for the tint bias sadly outside of buying a $100 lux meter.
Yep, I agree. I know for a fact that these meters (and every other meter I have tried in the sub $100 price range) are biased to cooler tints.
I just yesterday found out that my most used integrating sphere warms up the spectrum by a few hundred K, maybe I should use a cheaper luxmeter to compensate for that :party:
I would not do any math. It’s not about super accuracy. I would use the number right off the meter for NW lights.
For CW I would just bump it down about 3% worth. So a cool white light measuring 1000 lm would be 970, etc… Easy peasy.
