I like the way you think! Just get it done.
Now to track down some 0403s.
Regarding color, it seems like I read somewhere on one of millions of threads that the color green is the best for signalling or seeing in a busy environment because something to do with how we see colors. Does that sound like BS?
I intend to use the secondary emitters for location purposes only. Other people may be handling it or it may get jumbled into the mess while camping or something. Wanted to put a color on that is most conspicuous to our eyes.
Also, if anyone hasn’t had the luxury of using a battery with this capacity yet: if you don’t try to light up the night it will last for an amazing length of time. Unbelievable.
Finally, for size reference, if anyone has a Convoy BD06 this is very similar in size if you were to cut the head off the BD06 at the groove directly above the switch.
I am a novice but I would like to replace led to red.
I have some 0805 led they measure 3.21mm x 1.5mm.
That leads me to believe that the 0403 led is less than a millimeter,that seems too small??
Green is the sun’s peak wavelength, and most living creatures with eyes are sensitive to green light because that’s the strongest component of natural light. It also tends to be the brightest or most efficient color for emitters and for glow-in-the-dark stuff. Given the same power level for each color, green aux LEDs will generally tend to be the brightest.
However, blue works really well too, and will generally look pretty bright. Most of our high-power LEDs are blue underneath the phosphor layer.
Do we know the size of Emisar’s aux LEDs for sure?
Edit: I don’t have good tools for measuring things that small, but I think Emisar might be using 0603-sized LEDs. I’m seeing about 1.7mm x 0.8mm. They appear to be smaller than the clock kit LEDs, which I think are 0805.
It’d be nice if these things all used metric units, instead of inches.
Not in that context eas, but when they hold off buying til the impending next revision, already sure at announcement that there will be changes, then things get a bit wonky.
My sense is that, at least among likely buyers of Emisar lights, the % of people who will wait for an anticipated update is relatively small compared to the % who will buy one now, and one later.
You can usually reflow a 0603 on a bigger 0402 footprint like I am using
this is what I did on my new Generation 3 tail board a dual footprint, I changed the wideness of 0402 a bit
on the D4 I had to use normal 0402 footprint as its very limited space
I found this info on the WWW.
SMD LEDs are available in four sizes, which are designated 1206, 0805, 0603 and 0402 . 0402 is the smallest, with overall package size of 1.0 mm x 0.5 mm x 0.45 mm (L x W x H). Then 0603 at 1.6 mm x 0.8 mm x 0.6 mm. 0805 are slightly larger, at 2.0 mm x 1.25 mm x 0.8 mm.
I measured the 0805 at 3.21 x 1.5,I measured from flange to flange on the bottom.
Looks like they are all available for reasonable price.
There’s probably a thousand components that size in my cell phone or other consumer electronics, but I’ve never come across those tiny things in stuff I’m building myself, and I hope I never have to. No thank you.
So did we arrive at a consensus on size? That comparison photo with the ruler only shows tab flanges on 0603 and larger sizes, and I’m pretty sure TK’s pics in the very first post of this thread shows flanges on the LEDs. So I’m thinking they’re probably not 0402s…which is good. But I’m not sure that’s definitive either. I’m prepared to wait and see when my light arrives, I’ve got both 0603 and 0804 on hand already, but I don’t have any 0402s here to try if that winds up being the right answer.
