Very excited about this light. Held off on the Emisar D4 because of the quick thermal step down. Looking forward to see user reports and first impressions.
Several questions for you guys.
Which one (Nichia, XPL Hi, etc) have you been ordering?
The Nichia runs hotter and is less bright than the XP-L HI. But what about when the battery is at half capacity, with less voltage? In this circumstance, since the Nichia has a lower Vf, does this not mean the Nichia will have a better “regulated” output compared to the XPL - HI without significant drop in output?
In other words, other than CRI and TINT, does the lower Vf of the Nichia have any advantages over the other emitter options? Do the lower Vf LED’s have advantages with certain drivers only (ie, Boost, Buck, Linear, PWM/DD)?
I emailed shockli and they did not reply and also windyfire they got back to me and said they were not sure if could ship to Australia but never heard any more.I have just ordered some Keeppower 6000mha from supersport 600,expensive but will arrive in a couple of days .
Some of the lights should be hitting the USA here in a few days.
I am hoping that it is not going to be October for me, like it was for the Q8…. Thank you DHL, putting it on an actual shipping container that sat in port (Seattle) for 3 months.
We have a similar shipping problem to Canada right now. I could not find a source for the Shockli at any reasonable price but I found a store which claims to ship the LiitoKala which are close enough in capacity for me. I hope I’ll actually receive them.
lol thanks Dale glad you responded as I’ve never ordered from them before so not sure how there shipping is etc...All my other torches are from zebralight.
If you ramp to 600 lm, it will do on/off at that level by default unless you switch to a different level.
Or there’s the stepped ramp, which can be configured for anywhere from 2 to 150 total steps. It’d take a bunch of clicks to set either end to 600, since that’s pretty close to the middle of the ramp, but I think you could set both ends to 600 and the number of modes to 2, if you really wanted it to only do that.
It’ll still have access to turbo though, and access to other modes (including the smooth ramp). There is no muggle mode in this UI.
Or you could ramp to 600lm and go to momentary/tactical mode. It’ll stay there, at that level, until power is disconnected.
In my strong opinion all hotrods should have a muggle mode, that can not be activated by accident and that can not be disabled by accident. The X5/X6 firmware had a good working one, I wished that Hank had seen the value of it.
Sometimes I’d even leave my X6 in muggle mode, because it’s useful as a second mode group.
At least the D4S can switch between two ramp modes, since they each have their own floor and ceiling values. Like, one for indoor use and one for outdoor use, or however the user wants to configure it.
In place of muggle mode, a cell that won’t deliver high performance but otherwise still works is a good idea. Like a Panasonic B, it’ll work fine, it just won’t burn anything.
Rats, just received a refund for the battery amount. Are the Thrunite 26650’s fairly good? Might get a NW Catapault V6 and borrow the battery out of my cool white for the D4S.
I ordered the Nichia D4S as I don’t have anything with that led. I’m still a total noob with only a half dozen lights, but figure I might as well see what this whole high CRI thing is all about.
