And less than 1/3 says yes. Or do I interpret it wrong?
I didn’t answer the poll due to some reasons:
I don’t actually mind if it will have tritium slot or magnet hole as I don’t know if I will have a trit to put in there, and I don’t know if I will want a magnet there or not.
Both things will be assessed when the flashlights arrive to my hands and then I will decide.
If, one the one hand, I’d prefer not to have a magnet installed as “stock” , one the other hand, I’d like the possibility to install a magnet later. So, the magnet hole can be handy (even to fill it with GITD powder and epoxy or resin).
And the sames goes for the trit slot.
This means that if I was going to answer the poll it would be a double “I don’t care”!
This is not a personal justification, only a way to interpret the answers (maybe other members felt the same too)!
The proposed design - in which magnet hole and trit slot have place - seems to be a very good option that combines the 4 “needed” things: lanyard/keyring hole, magnet hole, tritium vial slot, tailstading capability!
TheShadowGuy, djozz and iamlucky13, thank you for your work so far!
I know that whatever the final decision is it will be good, even knowing that it will not please all the interested people here!
I just want to have those “built like tanks and almost bullet proof” flashlights on my hands
No, let the slot in. You don’t win anything leaving it out, you need the lenght anyway because of the magnet.
I voted with I don’t care, but let it in it doesn’t harm.
Trit slot is easy to fill in, same for magnet hole - does no harm
Good morning! Here are the results from the survey:
The overall victor is the Noir/Djozz tail, including both the trit and magnet holes.
28 respondents voted for the N/D tail as their top choice. The next highest was the Olight tail at 10 respondents. The N/D tail also had the least 4th place finishes at 3, while the Olight tail had the most fourth place finishes at 17.
21 respondents liked the N/D tail as-is, including both holes. 10 would prefer no holes, 2 no trit, 1 no magnet hole, 1 wants another tail if holes are removed, and 11 don’t care.
As far as other comments go:
The Noir/Djozz tailcap is the best design concept I’ve ever seen. It maintains as much of the circumference as possible, which is what you need for maximum tailstanding stability, but still allows the light to hang vertically. It even lets people install a magnet or a trit according to personal preference, instead of being forced to take whatever the manufacturer thought best. I won’t use the magnet hole myself, but I’m seriously considering trying a trit for the first time ever. I’m not worried about unused holes trapping dirt, because the light’s going to be waterproof for washing anyway. I can always fill an unused hole with glue if it turns out to be a problem.
Both holes is the best compromise and it makes the light feel more unique having the tail designed by forum members.
No magnets or trits that makes the light longer, side hole might be good. As short as possible and sturdy is my wish.
There were other comments as well expressing opinions on holes, as well as another person mentioning that magnets aren’t great for keychains.
Sounds good to me. I’m please with the tail design. Thanks to all who have contributed to this project so far!
Thanks TheShadowGuy for the poll, the results and the discussion.
LOL, it is not easy to integrate those two surveys, for correct interpretation it is even relevant how many people have filled in both surveys, this overlap is unknown. At least it is clear that the magnet hole is there to stay and there is no grand winner in wether to keep the trit-hole or not.
I’m tempted to (mis-?)use the confusion to my own advantage and ask Sofirn to keep both holes. Keeping the design as is is also the easiest story for them.
Anyone with great objections to this blatant mis-use of democracy?
Democracy (mob rule) is overrated…
djozz/noir design all the way!
Go for it
Democracy is overrated ;) , I hereby declare my brainchild to be the victor :CROWN: .
Kidding aside the polls do seem to suggest that the majority support, or at least will be ok with the design (with both the magnet hole and the trit slot). This is of course also the most flexible option.
And since it is completely impossible to please everybody at the same time, I think it is best to just go ahead with this design.
Democracy is overrated , I hereby declare my brainchild to be the victor :person_with_crown: .
I agree. May the Schwartz be with you.
Could you please add me to the list for Qty-2
Thanks!
Thanks!
Which flavor? 3200k or 5600k?
Yes! Let the fabrication begin! Or as the King once said, “A little less conversation, a little more action!”
In for two of each.
I really like the Noir/Djozz design as it is.
On principle, I think it should have both holes, even if the majority who care won’t use the trit hole.
The reason I say that is because the people who want a trit and/or a magnet need the corresponding holes, or they can’t do it at all. On the other hand, the people who don’t want a trit or a magnet don’t lose any function if the holes are present; they can just ignore them or even fill them in.
Forget democracy, it’s time for an Imperial Decree
I put Elmer’s Glow in the Dark glue in my trit holes.
Elmer’s on the left, green trit vial on the right…
Of course I charged up the glue “trit” for the photo…and it will fade of course…but not bad…
Wouldn’t adding a vial of trit to a $6 light be the same as putting $1200 worth of wheels and tires on a ’74 Pacer?
Maybe so, but I have some spare trits left over from other projects so no new cost - hopefully this light will be tough enough to out last the trit.
Man Without Shadow, how well does the GITD glue stay in place?
