Any idea whether your black Liitokala is genuine or not, assuming there is fake Liitokala 26650 cells now??? Do you remember roughly when you ordered your Liitokala? And if you have an analysing charger, do you mind checking the capacity of your Black Liitokala 26650 cells?
I was all set to order a pack of 4 Black Liitokala 26650 cells from them till I noticed several more recent posts suggesting Liitokala Official Store on AE also sells fake non-Liitokala cells, so I am starting to wonder if they sell fake Liitokala cells too??? See post here today by ledoman indicating their Panasonic NCR18650B are fakes! Here is another post by Barkuti indicating he has received fake Samsung 25R cells from them as well.
You really need to get a MT09R man. I got one modded by TA in blue; looks fantastic and does 21,000 lumens. I love the blue finish on it.
The SC26 group buy is still going on I think. Cool little light, same blue finish, but it badly needed a different driver and UI. I’ve been searching for a 28mm boost driver with Narsil and side switch LED support, but haven’t found any yet.
You can buy it from BG and have it shipped to TA for modding. But the new V2 already comes with the TA designed driver and also have factory spring bypasses. The only thing you might want TA to mod is the emitters. We don’t know what bin emitters the factory comes with but TA can help you put in top bin emitters of a color temperature of your choice.
Anyone know how you ramp the Aux LEDs? I clicked 7 times to get it to low Aux, but when I click again it just goes into ramping of regular leds. Curious to see how bright those blue aux leds could get.
Yeah, the aux LEDs don’t ramp. The ‘high’ mode on them is as bright as they get, but you can change that by swapping out the resistor on the aux LED board.
Got my Green Emisar from Mtn Electronics today, so I cleaned the contacts and springs with NO-OX-ID “A” Special and popped a Black and Gold Liitokala charged to 4.21v set the meter on the T/A maukka calibrated tube to MAX hold….and got 4,840lm. at turn on…
Spaced the battery tube out with (2) 2mm x27mmx30.5mm copper sealing rings, so I didn’t crush the springs, when using a full charged 4.21v 21700 30T and registered 6,070lm. at turn on…
Bad to the Bone stock Rocket! :+1: And yes it still works fine… :person_facepalming:
Thanks. I still can’t seem to get it into “high” mode. I do the 7 clicks to get it to aux LED, but no matter what I do after that, it still seems to be on low.
Thanks so much! You’re totally right. I couldn’t even tell when it was on low mode because there is still a good deal of light in the room. It is very faint.
Received my D4s from MTN today, the size is slightly bigger than I expect!
From L to R: Fireflies ROT66, D4s, DQG Tiny 26650 3th & Haikelite SC26 (26350 tube).
Holy cow this definitely is brighter than the D4! 6,000 lumens with 21700 makes it even more insane!
Btw, do you really mean you cleaned the contacts and springs with NO-OX-ID? I thought it was only used as a thread grease but with electrical conductance for reduced resistance through the threads. I have the NO-OX-ID too but from my testing, it didn’t increase any lumens unfortunately.
“NO-OX-ID electrical contact lubricant prevents the formation of oxides, sulfides, and other corrosion deposits and is also used as a battery terminal grease”
Not sure where you got the idea it was a thread lubricant, it’s formulated to clean electrical contacts and provide a non-oxidizing layer of protection to maintain optimum battery to contact performance.
Perhaps the lumens reading from that box is questionable, who knows… far be it for me to say… but I DO see that it’s not mating to the lights properly in Kawi’s pics of the TN42.
