Thanks. I still can’t seem to get it into “high” mode. I do the 7 clicks to get it to aux LED, but no matter what I do after that, it still seems to be on low.
Thanks so much! You’re totally right. I couldn’t even tell when it was on low mode because there is still a good deal of light in the room. It is very faint.
Received my D4s from MTN today, the size is slightly bigger than I expect!
From L to R: Fireflies ROT66, D4s, DQG Tiny 26650 3th & Haikelite SC26 (26350 tube).
Holy cow this definitely is brighter than the D4! 6,000 lumens with 21700 makes it even more insane!
Btw, do you really mean you cleaned the contacts and springs with NO-OX-ID? I thought it was only used as a thread grease but with electrical conductance for reduced resistance through the threads. I have the NO-OX-ID too but from my testing, it didn’t increase any lumens unfortunately.
“NO-OX-ID electrical contact lubricant prevents the formation of oxides, sulfides, and other corrosion deposits and is also used as a battery terminal grease”
Not sure where you got the idea it was a thread lubricant, it’s formulated to clean electrical contacts and provide a non-oxidizing layer of protection to maintain optimum battery to contact performance.
Perhaps the lumens reading from that box is questionable, who knows… far be it for me to say… but I DO see that it’s not mating to the lights properly in Kawi’s pics of the TN42.
Thanks for the clarification. I found the no-ox-id recommended by someone in a thread lubricant thread and I bought it for that purpose. I never realize it wasn’t intended for that. However, it does work well as a thread lubricant and being meant for electrical contact means I don’t have to worry about grease getting on my batteries and springs. I’ve been having problems with my TC20 turbo mode because thread grease gets on the battery contacts and I have to clean with alcohol to fix.
KawiBoy1428 thanks for the info! Where did you get the copper rings? Also, are there cheap 21700 -> 26650 spacer/sleeves available anywhere? A quick google search only turned up brackets but not sleeves. Thanks!
Jordan, Kawi makes the copper spacers from copper washers usually. It’s not so much a 26650 to 21700 spacer as it is an extension for the D4S tube to make the gap longer, to fit the longer cell. Emisar makes the lights very compact, not much room for us to mod them, so to use the longer cell takes some creativity… a copper washer fitted between the head and tube and another between the tube and tail cap gains this bit of length that’s required. Kawi has a lot of experience finding the loop holes.
It will probably have a shorter life span, yes. But when it’s normal life span is measured in terms of 50,000 hours what is a short life span? 10,000 hours? 1,000? Far more than most of us will ever use a flashlight.
In this case, djozz has tested the XP-L HI to near 1800 lumens, in Kawi’s light the emitters have to be making some 1750 lumens to make the 6000 lumens that box measured. (optic loses 9, lens loses at least another 3-5 and that’s being gracious, not counting any driver or wiring, trace, switch losses) So yes, pushing these to their theoretical limits we can expect they will have a reduced life… still acceptable to most of us all things considered.
Just a quick reminder: It may be feasible to mod a D4S to increase its peak output from ~4800 lm to ~6000 lm, but it’s not really going to be a visible difference. It’s mostly a thing to do for educational purposes, or for the joy of doing it, and not for any practical benefit.
Definitely go ahead and max out the lumens if you like; it’s great fun. It’s just not going to be noticeable without a lux meter.
