single xm-l lights /beamshots
just a simple test with my single xm-l lights :)
left to right:
-MTE modified with xm-l T5 direct drive
-Lumapower clone xm-l with amc7135 3040mA
-HS802 clone with xm-l T5 direct drive
-Jetbeam bc40
-Uniquefire X8
-Keygos ke-1600
-Ultrafire D1 with modified driver
spot comparison, the sequence is the same as above:
mouseover faster shutter speed
mte 12kcd luma 25.5kcd hs802 31kcd bc40 24.5kcd UF X8 32kcd keygos 37kcd UF D1 53kcd
"tree shots" ~ 50-60m
mte xm-l
lumapower xm-l
hs802 xm-l
jetbeam bc40
Uniquefire X8
keygos ke-1600
Ultrafire D1
"building shots" ~ 150m
mte xm-l
lumapower xm-l (C8)
hs802 xm-l
Jetbeam bc40
Uniquefire X8
Keygos ke-1600
Ultrafire D1
nice write up and beamshots - thanks!
Why no C10 zoomie in there - yours is xml, no? Ok, ok, because it would look totally different than everything else lol. I haven't modded mine, yet, so I'm curious
Nice shots! Thanks for doing this. I like the Keygos, good throw and a ton of spill.
Thx for this! The all-in-one mouse over was a great idea!!
thanks to everyone
dthrckt,
tomorrow, If the weather permits :)
1. xm-l with 50mm lens
2. xm-l with 40mm lens
both direct drive (that means ~4A)
same camera settings as in the first post, of course
xm-l with 50mm lens
xm-l with 40mm lens (mouse over -> flood)
xm-l with 50mm lens
thanks!
I have two 50mm from DX but they're terrible at full focus :( That's really too bad because the 50mm would be awesome improvement to tractor supply 3xD zoomie...
I don't know, mine isn't so bad.
Here, it is a little out of focus (third spot), but I haven't problem with it. Little distortion, but hey, it was $3. :)
Can we have more info on these? Is there a separate post? The host, build, more pictures of the assembly?
Thanks!
Viktor
a moment...
this is the 50mm aspherical light:
The lens fits perfectly into the tr-500 tr-1200 head. I made a copper pill, heatsink, what I pressed and glued into the battery tube. Now it works with 1 cell.
this is the modified SMALL SUN ZY-C10-S:
I threw away the orig lens and replaced with a better one. I had to lift up the emitter, because the focal lenght of the lens is short. Now the original bezel doesn't fit, temporary got a protective plastic bezel.
Any chance of you opening up a new post (or two) with more details on each?
More picz! :D
Viktor
Can you give us some details on the driver mod? Was it an upgrade or a repair, what's the difference before and after, which replacement driver did you use? Thanks.
*EDIT* Nevermind, I think I found it... here (posts #50 and #70). Thanks!
okay :)
Awesome! Thanks for sharing, very useful indeed!!
Could you post kcd readings for the two aspherics flashlights (40mm and 50mm)?
Hard to tell an exact value, because the brightness changes through the projected die image. The upper part always the brightest. A good average value for the 50mm ~ 50-60kcd (upper part 70-80k!), and for the 40mm ~ 35kcd (upper part 45-50k), I don't know the exact emitter current, both direct drive, somewhere 4A...
