One strange behavior I noticed. When I set mine for stepped ramp with 10 levels and exclude the turbo with 5 clicks in the ceiling ramp config, the light cycles immediately from top to bottom mode and doesn’t stop at the top. I feel it would be more consistent for it to stop at the max just like with turbo on the unlimited ramp.
However, if I click 10 times to limit the ceiling it does this, but the max step is much closer to turbo than with 5 clicks. Works well with 20 clicks as well with the ramp max being at a more suitable level.
Also it would be handy if you could exclude the turbo from the stepped ramp max by just one click. So the ramp config would be aware that you’re in the stepped ramp mode and adapt to the currently selected mode count.
On this light, I personally like XP-L HI ~5000K the best, and XP-G2 3D (~4885K) as a close second. Nichia is nice, but I just haven’t been as happy with the 219c as I was with the older 219b. The 219b emitter is probably the main thing which makes the ROT66 interesting. It doesn’t make as many lumens per emitter, but it makes really nice-looking lumens.
It looks like you found a bug. I tried a bunch of different combinations and they all worked, but 1/145/10 fails as you described. I’ll have to investigate that soon. Probably just a quirk of how the integer math works out, but it’s still quite odd.
If I understand correctly, you want it to let you choose the floor level and the number of steps, and then it would place the ceiling automatically one step below turbo?
I have 10 levels set for stepped ramp. I go to the ramp ceiling config and click once. This should give me to moon + 9 + turbo, where the turbo has to be double clicked. Similar with floor. I click twice in the config and I get moon + 8 modes with the lowest two discarded. So if I limit the ramp, I also get less modes, but I always know how many.
Valera, my D4S should be here in the next couple of hours, I will try to get a meter reading on lux/throw as soon as I get it.
I didn’t read my copper build because it has the new Samsung emitters, these are not factory available so the result would be irrelevant compared to the lights everyone is currently receiving. But with the Samsungs, beam distance is not very good out in the wide open, 100m and it’s difficult to make out objects like a young black calf separated from his mom. I’m sure the XP-L HI would show a different result, but this Ledil Angie optic is new to me so I don’t have experience with how it performs over different emitters.
Edit: Hank does state lumens and candela on his Intl-Outdoor site…
OTF lumen output and candela at start-up
XP-G2 S4 : 3300lm / 40,000cd
Nichia 219C : 3000lm / 20,000cd
XP-L HI : 4300lm / 45,000cd
40,000cd would reach 400M, 20,000cd would reach 282.84M and 45,000cd would reach 424.26M (according to the math) [square root of the candela x 4]
I just received my pair of D4S from Mountain and am thrilled with the results. The XPL-HI NW 5000K and the Nichia 216c 5000K 90CRI. Pleased to report both a winners in the tint lottery, very pleasing to the eye with excellent color rendition, a truly neutral white. No noticeable tint artifacts or shifting. If the rest of the light was mediocre (which is FAR from the truth — it is excellent!) I would be sold on the quality of the emitters ALONE.
I did notice fairly quickly the Nichias generate much more heat more quickly at high output levels, and after 60 seconds of turbo the XPL-HI was noticeably brighter, also $18 more expensive.
Im so impressed with the quality of tint on both emitters, the clincher for me, that if you had to have just one, spend the extra and go with the XPL-HI 5000K NW. The Nichias color rendition is superb, perhaps offsetting its heat penalty, which is really only evident at long interval high level settings/turbo. With fully charged cells, the Nichia is actually noticeably brighter than the XPL-HI NW with 3.7V cells.
The real lottery winner is the XPL-HI 5000K NW. Compared to the BLF Q8, the D4S XPL-HI NW has a much better, even pure white tint, vs the Q8 and its yellowish halo around the hotspot and slightly warm artifacting in general.
While not 90CRI, the XPL-HI impressed me greatly with its color rendition quality. Produces less heat and greater overall output than the Nichia. Bottom line, if it has to be one, go with the XPL-HI NW 5000K. OTOH, the exceptional tint quality of BOTH is so good, the die hard tint fanatic should be very happy with BOTH. It’s really a best of both worlds scenario here with the excellent D4S.
I was going to experiment with the XP-G2 at 5700K, but budget limitations kicked in. I’d be really interested to hear from someone with the CW 6500K XPL-HI and how it compares to the 5700K XP-G2.
I used to be a die hard CW fan, yet recently have warmed to neutral tints in favor of sheer maximum lumen numbers, perhaps a midlife crisis adaptation, hmmmmm.
One small nitpick, but serious. The lanyard mounting hole is a very small square cut machined into the end of the tailcap, its edges are RAZOR sharp, a bit uncomfortable. Requiring a bit of Dremel massage or grip tape to cover it.
Oh! Almost forgot... the Bonus Easter Egg feature... the (i’ll Wager it’s neodymium) magnet in the tailcap is wonderful, extremely powerful, so you will love it or hate it. With it, and 2 D4Ss, you easily place them end to end (be CAREFUL when you do this, at first) and together they form a very strong bond, in fact an entirely new Q8 Killer form factor: like the double-edged Light Saber from Star Wars.
End to end, its a much more comfortable, naturally balanced, lighter weight, and better fit in the hand than the BLF Q8. In ceiling bounce tests, the XPL-HI NW actually edges out the BLF Q8 with 30Q cells on turbo and holds its own against the BLF Q8 over most of its battery life, with just a single (the exceptional Shockli 5500mAh 26650) cell.
When 2 are conjoined by tail magnet, you have double the runtime AND output for less than the weight of the BLF Q8. It’s a single cell Q8 killer, that when doubled, becomes a Q8 Dominator. My fun nickname for the D4S Squared Configuration.
For the true DieHard: The D4S Squared “Dominator” EDC, if it has to be only One... (here’s 2-in-1 :-) )
Conclusion: this is an exceptional “total package” flashlight, with every detail for high performance already turn-key and built in, and an exceptional value for the money. Highly recommended, with exceptional prompt customer service and shipping from Mountain Electronics. Kudos and Thanks, Richard !!
Congrats to the other owners, and strong recommendations to the BLF community!
- I notice the Anduril for D4 doesn’t identify if it works for 219C or XPL-Hi (my guess is it works for both)
there are 2 different Anduril files for D4S - one is for 219C while the other is for “the others” — my guess is the 219C also follows the “80%” of max power, that was mentioned above, or are there other differences?
Another question: where can I find the “stock/factory” hex files for RampingIOS v2 (for D4/D1/D1S) and stock RampingIOSv3 (for D4S)? In case I want to test the “stock” firmwares again after flashing them to other firmwares like Anduril…
