Well that makes things interesting. It’s both easier and harder to connect to the line of flat pads — easier because I assume it fits a standardized set of jumper pins or something, harder because it has no holes so one cannot just shove wires through it.
I hope Lexel’s connector becomes widely-used soon, and I hope we can get someone to make and sell the keys or flashing kits fairly cheap.
Yep, they are a really good performing cell….IR on my Sky RC charger puts them at 16.
Had to check my D4S with only the driver spring removed and a brass contact added as the only mod to an otherwise stock light. 5,650lm on the other IJOY @ 4,21v.
Also checked the wife’s Stock D4S I got today from Hank using the IJOY 26650 4.21v off the Sky RC charger 5,050lm @ Turn on.
I got the light the other day, with the V3 Hi’s. Throws further than expected and with a better beam profile than expected. The UI is great. The aux LEDs are pretty. Very nicely done. This light is a big deal.
So here is the comment made by skylumen ( pro modder ). He doesn’t go to blf. Here is what he wrote, “ D4S just came in. WOW, this is the best Emisar.”
Thanks TK, Hank, and everyone who succeeded this project.
Kawi, that is freaking incredible that you got 5000+ lumens. Which emitter did you get? I only got 3,800 lumens with my D4s XP-L HI 5D using my TA tube calibrated with Maukka lights. I’m kind of disappointed. I was expecting 4.5k lumens
ZozzV6 - Those are the same four lights in the same color combination as I have. The only difference is I usually have the short tube on the D1 to make it more pocket-friendly.
