Wow, I just put TK’s preconfigured Anduril on a D4. Awesome!
Love being able to configure the ceiling and still have turbo if needed. Will really help with battery life.
Of course all of the special modes are super-cool, will be going to bed with the Sunset or Candle mode every night!
Fully configurable beacon is the best beacon yet.
Thanks TK for all of your hard work!!
Has anyone tried running Emisar D4 with flat top cells?
Thing is… I have both flat and button top Samsung 30Q, all around the same age, but I have felt that with the flat top cell the light output is lower.
Today I have it confimed by a luxmeter in my phone. Ceiling bounce, same setup, flat top cell shows around 360 lux, button top cell 450-ish. Which is quite a significant difference.
Can anyone confirm my findings? Could it be due to lower pressure on the springs because flat top cell si shorter?
I purchased all those items except the extension cable. you only need 6 wires IIRC, but not I bought a wide cable like suggested. I also bought this item and was glad I did. It allowed me to verify my test setup while I was waiting for the clip. The clip I purchased was the cheaper alternative. The Arduino board is definitely not required, but for a few $ more it provide me chance to practice before connecting with the real part on my board. I used the Arduino board just to connect to the ATTiny85 and verify the rest of my setup was good, I also flashed it with Anduril, just for practice.
dgq3, you’re probably right… spring compression can make a lot of difference in output, I see it all the time on the light box. The flat top 30Q should have better performance as it doesn’t have the added steel button top which has high resistance comparatively. You can see the internal resistance value of the cell on a charger like the Opus or MiBoxer C4-12. Edit: The manufacturer’s make these cells for battery packs, like in drills or such, and don’t put button tops or protection circuits on the cells. Aftermarket sellers add the button top or protection circuit, with a wide variety of issues associated therein. Sometimes these added button top plates are welded on nicely, sometimes not. Sometimes not at all, only being held in place by the insulation disc and the wrapper.
I just put a pair of Samsung 30T 21700 cells on my MiBoxer C4-12 and saw internal resistance values of 13 and 14. After testing with one and putting it back on the charger, it showed 9!
I have Nichia and XP-L 3A 5000k and the best tint with no doubt is Nichia, the tint is a relatively white but when illuminating shows very natural colors. The XPL-HI 3A is not a bad tint at all, but compared to the Nichia it loses.
The problem with the D4 Nichia (not so much in the D4S) is the heat, which makes that the stepdown constantly lower the power.
It hard to get from gtranslation, but author choose more simple way. Boost driver with s2p2 led config. You can see there that mcpcb has bypass and cut to change config.
The black D4 has been sold out for some time on intl-outdoor, if Hank would have been in time making new ones his sales would be better (I do not see the black D4 ceasing to be popular any time soon, even with new models, the D4 is simply the best Emisar light). Does that maybe indicate that an upgrade D4 is in the make?
I don’t really know Hank’s plans. I fixed a stepped ramping bug though, and am going to send him an updated copy of RampingIOS V3 for each Emisar light.
The bug isn’t a serious one; it just acted weird when two ramp steps were exactly 128 levels apart and the step size happened to land exactly on the guess from imprecise integer math.
Anyway, I’ll send it but I can’t guarantee he’ll use it.
Can anyone tell me the screw size for the two screws that hold down the LED PCB? My aluminum D4 has flat head screws which allows for my 3D printed glow gasket to fit just fine. My D4 TI I just got has round head screws. Much too large to allow the 3D gasket to fit under the optic. I would like to get two flathead screws for my D4 TI.
My aluminum D4 has the round screws too, but the threads will be the same.
I could take one out and measure it tomorrow when I have my tools, but any fastener store worth its salt should be able to help you if you bring it in. They will be able to measure the length, diameter, and thread pitch, and if they don’t have it they should be able to tell you where to get them.
