@Mark M
Writing the manual and checking if everything is OK would be easier when the writer has a lamp to compare.
But there is never one. Only asking stuff via emails.
I’m fairly sure it will shut down, and I don’t believe you’ll be able to push the 30Q’s to far, you can run this light on 4 batteries, actually I think it will run on one if I recall. I can assure you that there’s nothing to worry about especially when TA is behind the drivers functions.
Newlumen, are those Astro’s on both ends?
If so how are they ? Been looking at those and thinking about getting one but really they look like knockoff GT’s, still tempted though… ha ha
I’m Addicted to anything that lights up.
I read the user manual and didn’t find mention of auto shut-off when battery voltage is low.
I think that information is worth inclusion in the user manual if Lumintop decided to revise the user manual.
Gives the user more fun in using the flashlight knowing that it will auto shut-off or give some conspicuous signal like flashing of light when the battery voltage reached a certain low-voltage level.
I don’t know what will happen If I let the flashlight drain the batteries down in use. Will it explode in my hands?
Hey Verge on the first page of the user manual titled Safety precautions which was for the GT XHP35 but same thing as the GT70 it says on section 4,
Remove and recharge cells when the low voltage indications is given by the GT (repeated step-downs in light levels and eventual shutdown of the light.)
Direct quote for you friend, so have fun and no worries…
When voltage reaches 3v it will blink 3 times and step down to a lower level. I think it will shut off the light completely at 2.8v. (Don’t qoute me on the exact voltage) So there is no chance of over discharging the cells.
There is a small amount of parasitic drain when off, though. So if you don’t plan to use the light for several months, it’s best to turn the tail cap to cut all power.
The emitter is 12v so you have to have at least 4 cells in a carrier. The other carrier can be empty if you want.
Thanks for the info Newlumen, I think I’m going to pass on those as tempted as I am, I am getting way to many huge lights lately but I’m darn happy that’s for sure.
Is purchasing flashlights tax deductible on my income tax, ha ha Mr. JASON… ha ha ha
I remember reading in one of the posts in this forum or at the other forum some years ago about rechargable lithium batteries exploding inside the flashlight.
The explosion caused the flashlight’s end cap to shoot out like a bullet and fortunately just hit a wall.
The story I saw on the other forums was where the light got insanely hot all of a sudden so the user dropped it at which point it blew up and ended up putting a pretty big dent in the bottom track (likely alloy) of their sliding door from the end cap or the head shooting off under immense pressure. They then had to deal with hydrofluoric acid inhalation and potential poisoning. Not fun.
I think battery technology has come a long way since then so I am not overly worried. You’ll hear of vapers popping their toys before us flashaholics!
Picked up in Singapore late Friday night (AEST) and delivered today, Monday, at about 1pm. Not bad DHL! Obviously it went out after the US shipments or the service they used to get it to DHL in Singapore was a bit slow. Either way, I can’t complain about that!
So…the GT70…hmm what a beast. My biggest light up until now was a Thrunite TN40 which is just dwarfed by this gigantic monster.
As for springs, mine all seem fine. Ordered batteries seperate so obviously no damaged cells.
The lens had a big spot of moisture (looked foggy like some lights get after a while on high) on the inside of the lens, dead centre, about 3cm in diameter. Turning on the light for a few seconds of turbo a couple of times and it has disappeared. I’ll keep an eye on that, hopefully don’t have to use some silica gel packs to dry it out.
Now, onto the reflector, there is a noticeable deformity on the coating but doesn’t appear to show up in use. It looks like a tiny ripple and has to be moved around to be seen but if you know it is there, it is really easy to spot. I am less concerned about this than the possible moisture trapped in the head but will have a better look when it gets dark to see if I can see any artifacts in the beam. From what I have heard about the past issues with original GT release, this is nothing to worry about as some of those were reportedly quite bad. I don’t have a good camera and my galaxy S9 doesn’t pick the defect up unfortunately or I would share images.
