I’m going to ask one more time. Are there any plans to offer spare parts for the GT70?. Like switches, driver boards, lenses, etc? It’s an expensive flashlight. I want to be able to fix it if something goes wrong.
That is a very strange issues, I have not seen that before on a quality reflector like this.
It is also something that would easily slip through QC unless you were looking for it so pretty much positive that it is just a case of someone not seeing it and not lumintop using lower grade parts.
Contact leo for sure, they should send you a replacement.
Boy that would be horrific to find out that we are getting factory second lights and BG is getting the A+ lights, just a thought because there is no way I could see Lumin ever doing that to us.
I see this product everywhere for sale and I always thought that when our team designs and has a GB that our members are all taken care of first and then it goes for public sales, I could be wrong or maybe a different agreement was made.
I’ve been fortunate since the first run and have gotten some pretty good reflectors compared to what I’ve seen in some pics since Dec. 2017, still has some spin ripples I believe it is but you have to look close for them.
And Lumin said they are worried about shipping a reflector by itself, it might get damaged, perhaps they should worry about shipping reflectors in the lights as well.?
Only thing that got me was those darn springs, had one stab deep into my finger the other night while looking for the springs that messed up some of my cells, 3 out of 8 cells I’ve gotten rid of and I bought 16 new from Liions, also been using my small file to file down the ends of all my springs to remove a 45 degree angled cut on the wire ends, that angle made those very sharp and some were turned upward not your normal 90 degree bend and that’s what caused what you saw in that one picture, that one spring could have worked a hole through that negative end for sure eventually, then I used my Smith Little torch to direct heat and bend the spring wire back down where it should have been, fairly difficult to do.
So that should fix my spring problems, nice and smooth now and all around fantastic light, now I just need to find a different LED,
I think I’ll get in touch with RMM and see if he will do the same thing he offered for the XHP35’s…
Thank you again TA for all your very hard work on this project, it is greatly appreciated…!!
My reflector looks a lot like the one Kingjohn posted. Obviously it isn’t as severe as it doesn’t show up in use, even when held close to the wall.
I have noticed the lens fogging quite a bit but I also noticed there is a hole in thr driver…
TA, DO YOU KNOW IF THE HEADS ARE FULLY SEALED? Would cracking the bezel open and putting it in a container with some silica gel be an option or will moisture in thr air just get back into the body each battery change?
The beam on mine is quite good, a bit cool but that was to be expected since I am more a NW fan. The ceilijg bounce app runtime function gave me a reading 4839 for 4x30Qs and 5186 with 8x30Qs. I should have tested the drop at 30s but am happy they are that close to start with.
One weird thing I noticed is the light clicking as it heats up and then subsequently cools off. Kinda like a the popping and clicking sound a tin roof makes when it undergoes thermal expansion/contraction. Anyone else notice this on theirs?
With all the minor “issues” I am still really happy with the light.
GREAT JOB TO TA AND EVERYONE ELSE INVOLVED!! Can’t wait to crack it open and dedome the LED and see what happens. Will likely order the NW when available and just leave it as-is.
That was changed this time around and I see it staying that way in the future. In the GT group buy a very disproportionate number of issues were the mere rumors that the light might go on sale somewhere else. Even though it was never said that BLF got first dibs, only that they got the group buy price.
I now make this clear in the OP to eliminate these issues and this is not an issue since lumintop has enough lights to go around this time, so they can fulfill all the orders equally.
Not to worry about one place getting better quality then another. All of the lights are in one giant batch and are not graded at lumintop. The individual parts either pass or fail QC. If they fail. they are sent back to the factory. This is why we could not get the rejected reflector from the first GT group buy.
The heads are almost sealed, the driver is just held in place by a retaining ring and there is a hole as you noted but when the light is fully assembled it is effectively sealed.
Yes, putting it in a container with some silica could indeed help.
The clicking is normal, it is just the metal expanding with the heat, this is much more noticeable on a large light like this.
If you can not see the imperfection in the beam even when held close to the wall, then it will have virtually no effect on the performance of the light. I have been surprised with even fairly large imperfections having little effect in the past.
Thanks for the beamshots… last week when I got my blf gt70 and I seem some hint of green… green tint disappears or less noticeable this week. Maybe led get break in or my eyes…
I can see green color in the corona only. And only at lower output…
Maybe because at high output I get blind and no longer see anything at all on a white wall :cowboy_hat_face:
The left spot in this pic is the de-domed GT.
Don’t be perplexed, the tint shit in the lower modes is horrendous, I can’t stand it. But from 50–100 power it is a massive change in tint. Get rid of the phosphorous around the LED and the corona is greatly reduced on a shaved dome, complete de-domed LED, barely a ring, usually a blue halo from the sides of the LED die.
Now the clean de-domed LED only measures 6,200lm, it was making 8,500-8,800 depending on what batteries I used, before I shaved it really close (meh too close I guess) and diced the pad clean, but then after a couple Turbo blast, it started to burn, so I completely de-domed it. Smoked up my reflector a bit.
