The BLF GT70 "Giggle Monster" is here! 7,500lumens, 1,500m throw! Group buy Closed!
Guys I have a favor to ask. Can someone please test the GT70 with the 35E cells from the xhp35 version? Money is kinda short for me right now and I wanted to know if the extra 40$ for the 8x 30Q set is worth it. Already spending 55$ for the conversion kit, I really don’t wanna drop 100$ right now unless it’s absolutely necessary. I have read somewhere that the amperage per cell, using all 8 cells, would be only 5 amps. I believe the 35E is capable of delivering that without much sagging. What I wanted to know is how much output will I lose if any at all. Thanks!
Did any in the USA that ordered caps and or straps for their light receive them with their light order. I was told by email that my caps and straps would be shipped to the USA with my light order, but that did not happen. I had great communication with Leo/Lumintop prior to getting my light, but now cannot get a response concerning the accessory order. Starting to get a little concerned about ordering a NW second light as regular consumer demand ramps up.
I don’t have Samsung 35e. I have lg mj1 which are similar to 35e… batteries are charging… will post lumen soon.
Thanks Newlumen! Very much appreciated.
I’ll charge mine for comparison purposes too.
The 35E’s will work fine but it will be less lumens. I am kinda curious on the exact lumen loss myself.
I’m planning on using my 35E cells, but if it will be better to use high drain cells I’ll pick up a set of VTC6 cells and solder blob them.
I retested the 30q in addition to the 35e. Both were fresh off the charger at 4.20v Each battery set had less than 5 cycles of 5 mins or less on them.
I let the light cool about 15 mins between tests. Light engine was cool to the touch at the second test start.
Same carriers used both times as well (both the correct GT70 carriers with the thicker aluminum) compared to the OG GT carriers.
30q
Start lumens 8,388
30 second lumens 7,147
35e
Start lumens 7,848
30 second lumens 7,087
Startup was about 6% lower with the 35e
30 seconds was about 0.8% lower
I ordered Giggle Monster NW.
Sorry if I sound a little ignorant, but I’ve been on hiatus from BLF. Imagine my shock when I saw the thread, Giggle Monster? Are we getting the dedome Giggle Monster or dome version? I think I prefer the dedome version.
Blf gt 70 with 30q. 6240 lumen
Blf gt 70 lg Mj1. 6200 lumen
I only test for like 5 seconds… so I think Samsung 35e should be fine…
Honestly i like all 4 blf gt. More powerful, and longer runtime… i even like my blf gt xhp35 CW.
Good testing, this is why I use 3500ma cells for most of my lights.
Also goes to show how much of the initial drop in output is heat related and how much is voltage drop. The first 30 seconds is where the heat path gets thermally saturated, I am surprised how close the numebrs are at that point.
They will be coming with the dome on at this point, I do not trust them to slice the dome in bulk right now. It is possible they might offer some with a sliced dome later but I would not hold your breath.
In other news I just got word that the Neutral white GT70 will be ready soon along with the conversion kits.
The final Neutral while LED will be a 5000k XHP70B-3C-P2 led as it was basically the only thing available right now without an 8-12 week wait for a special production run and a minium order of 3500 pieces. The 4000k they actually wanted to do but it seems the supplier sold out of them in the last few weeks and they are no longer available :person_facepalming:
No exact time frame yet but from past experience I would say the time frame in the OP should hold, sometime in the next ~2 weeks they should go live on the lumintop website and ship a week or so later.
At which point a new wave of emails will be sent out to everyone with a (most likely) new code.
The final Neutral White LED will be a 5000k XHP70B-3C-P2 LED
:+1: … Looks good except possibly for that “C” part. :wink:
……. Oh well, can’t have it all I guess. :smiley:
So this would be also good for dedome.
I like warmer tint, also in Throwers.
Same for me, I´ve a lot of VTC6 Cells and I´ve tested this with good results in other lights:
EDIT:
Maybe soldered magnets should be better.
I´ve got some solderwire from a colleague, that should have low melting temperature.
Is this DTP MCPCB with 12V configuration available separate?
And what about the driver?
I´ve some XHP70.2 P2 LEDs.
Sony VTC6 is considered a high drain cell so it is good. The 35E has more capacity in exchange for less amperage output. Still, when you use 8 of them you don’t see such a large difference in output. If you only use 4 x 35E cells you would get a bigger drop in output.
I would not solder magnets. They have high resistance. It’s better to just blob the solder. I bought some brass buttons that are 2mm tall and 5mm wide. I might try to solder them on instead of a solder blob.
The mcpcb is not available seperate. Only as part of the conversion kit.
From a couple days ago:
Ok,
thanks a lot.
So maybe I´ve to wait for that conversion kit.
Brass buttons have the problem, that if they get oxidized, resistance will be higher.
Thanks.
Too bad….
Will they try to get the 4000K version for a later time?
Thanks for the update!
